NP231 Rear output shaft snap ring? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > NP231 Rear output shaft snap ring?
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-15-2009, 11:41 AM   #1
Junixx
1994 XJ Cherokee
Well this last weekend I decided to get to work on my NP231, I have an older style case (94) and seem to have lost the snap ring that was holding the oil pump housing on, can anyone point me in the right direction to where I can buy one? (have yet to check a local store)
I also had another question, When I was took off the part before housing (not exactly sure what it is called o.o) there was no rear seal like this. (even though that is on a newer case) AFAIK, this case has never been taken apart, so im assuming it was meant to be like that?
I'll try to post pics later to explain more
Junixx is offline   Reply With Quote
Unread 10-15-2009, 01:48 PM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Any drive line shop or Internet seller that deals in rings and Pinions or SYE kits has or can order that snap ring. GOOGLE Omix-Ada and Crown Automotive Parts.
The picture seams to show a 1996 + Tcase with the external slip yoke. Your earlier style T-case has the internal slip yoke and does not need that seal.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 10-15-2009, 04:29 PM   #3
Junixx
1994 XJ Cherokee
Ah ok thank you very much, will get to it ASAP.
Unread 10-15-2009, 09:21 PM   #4
Junixx
1994 XJ Cherokee
Ok making sure before I order parts, The chain was stretched, filter was completely collapsed and broken, then the gear inside the oil pump housing was cracked, so I should be ordering this , this and this this? I want to make sure it won't stretch again. thanks in advance
