Np231 Problems - JeepForum.com
post #1 of 5 Old 06-01-2011, 02:59 PM Thread Starter
Shyster
Np231 Problems
Hey guys
I've been having some problems with my t/c after installing an SYE kit. It is generally hard and clunky to shift with either the linkage or the lever on the case. Going from 2H to 4H seems to be the hardest transition but when I can get it to go all of the modes seem to work properly after a little crunching and/or grinding initially. Another odd and perhaps telling thing is that when the t/c is in neutral and I try to put the tranny in park there is a light grinding noise and the tranny eventually crunches into park.
I've adjusted the linkage as per the FSM and it did seem to make a slight difference and I had no problems with the linkage before my lift/SYE. Also, all of the pads on the shift forks are good
Does this sound like a linkage thing or should I be pulling the case? If I need to pull what should I be looking for?
Thanks
Shaun
Shyster is offline
post #2 of 5 Old 06-01-2011, 05:23 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Did you install a Hack & Tap SYE or did you you disassemble the case and install a Heavy Duty SYE ?
CJ7-Tim is offline
post #3 of 5 Old 06-01-2011, 06:09 PM Thread Starter
Shyster
It's a rugged ridge Heavy duty
Shyster is offline
post #4 of 5 Old 06-01-2011, 08:16 PM
CJ7-Tim
CJ7-Tim's Avatar
I would guess that you have a linkage adjustment problem and just to need to try the procedure again.
Any problems with the SYE install or leftover parts ?
CJ7-Tim is offline
post #5 of 5 Old 06-02-2011, 05:11 AM Thread Starter
Shyster
Nope, no problems and no left over parts. I think I'm gonna pick up the Novak cable shifter kit, just because I never liked the way the jeeps shifted in the first place, hopefully this solves my problem.
Shyster is offline
2000 , cherokee , np231 , problem , shifting
HELP!!!! 91 NP231 tranfer case swap into a 2000 automatic with NP231 Greenmonster138 XJ Cherokee Technical Forum 15 07-02-2010 04:20 PM
NP231 output seal problems. z06rider XJ Cherokee Technical Forum 4 12-18-2009 02:54 PM
np231 problems on first big snow storm! :( Arbslikewhoa XJ Cherokee Technical Forum 4 12-11-2008 09:29 PM
NP242 to NP231 swap problems sabfoma2 XJ Cherokee Technical Forum 6 08-28-2007 07:51 PM
NP231 problems blakdot XJ Cherokee Technical Forum 7 09-19-2005 05:14 PM
