NP231 or NP242 - Page 3 - JeepForum.com
post #31 of 42 Old 02-23-2012, 04:03 AM
DezertXj88
1990 XJ Cherokee
aww boo.. I always read of everyone ditching the 242..figured I'd be the first/different lol.
The rear locker will be cool..and still have full time and honestly you can get a SYE & HNT for the 242 if I ever feel the need.
I just got my waggy clip on, so maybe now I'll go big! Big waggy Xj's are so sick!
DezertXj88 is offline
post #32 of 42 Old 04-15-2012, 06:29 PM
j69gordon
Originally Posted by xjfever View Post
The 231 is a stronger more reliable t-case, but if you do a lot of driving on icy snowy roads the 242 can be used in fulltime 4x4 without having to go from 2wd to 4wd as the conditions change. The 231 can not be driven in 4wd on pavement when traction is good. The swap will require a small amount of wiring to make the fulltime light work, but it is mostly a bolt in swap.
this is incorrect the input shaft of the 242 is 21 spline and the input shaft of the 231 is 23 spline, you can swap, however you need to tear apart the cases and swap input shafts, the rear driveshaft will fit fine, but the front will need to modified, because the front yolk is different. Also the linkage is not the same, if you swap a 231 in the 4 wheel drive shifter will need to be in the pulled back location for 2 wheel drive, and pushed forward for 4 wheel drive ( I am sure this could be fixed with a bit of ingenuity...)
now some 321's have 21 spline and this is a non issue, be sure to check it all out before getting to deep
j69gordon is offline
post #33 of 42 Old 04-15-2012, 07:20 PM
JT7771
231 vs 242
Originally Posted by Bain98xj View Post
What are the disadvantages and advantages of the 2 transfercases? and i have the 231 now but have a friend that has a 242 in his xj that he wrecked and told me i can take the tcase if i want before he starts parting it out. so would i be able to pull the 231 and put the 242 in without any major mods?
Hey Man, keep me in mind which ever T'case you don't want I will be happy tae off of your hands. I have a 231 now that has a hole through both cases. feel free to hit me up at JThornton7771@gmail.com
JT7771 is offline
post #34 of 42 Old 04-15-2012, 11:35 PM
Timo_90xj
Timo_90xj's Avatar
Check your facts, since pretty much everything your wrote is incorrect.
Both - 242s and 231s - come in 21 spline and 23 spline versions, it is dependant on the yearmodel of the XJ and which engine/ tranny is used. Basically all '91 and later XJs have 23 spline input shafts no matter which transmission/ engine/ TC combination is in question.
242s and 231s have the same 1310-series yokes on front output. Also front output is in the same location in relation to TC front mounting surface, so you can use the same front DS on both 231 and 242 as long as you're not doing any other drivetrain modifications that would require custom length shafts. There are a few different rear outputs (internal and external slip yoke, some XJs came with PTOs that had flange mounts for rear DS). The overall length on the 231 and 242 are slightly different so rear DS will or will not fit, depending on the possible lift height, rear DS being used, etc..
231 and 242 use the same linkage on the XJ so you do not need to swap the linkage when swapping TCs. Both t- cases have 2wd in the same location on the bezels (all the way forward), the difference is in 4wd modes and neutral position -> shift bezels are different and need to be changed when doing a TC swap. Or just ditch the bezels and go by the feel
231 modes are 2wd-4hi-n-4lo
242 modes are 2wd-4hi-4ft-n-4lo
***Under construction***
Timo_90xj is offline
post #35 of 42 Old 04-16-2012, 07:13 AM
jpndave
Timo is correct. Thanks for clearing that up.
jpndave is offline
post #36 of 42 Old 04-17-2012, 04:08 AM
j69gordon
i just swapped from a 242 to a 231 in my stock height 93 zj.
I cant post pics in here yet, but here are links to a couple, they show the planetary with input coupler, and without.... clearly different
http://i214.photobucket.com/albums/c...on/inputs2.jpg
http://i214.photobucket.com/albums/c...caseinputs.jpg
the left is out of the 242(with 21 splines), and the right from the 231(with 23 splines) so I was speaking from my personal experience. If that steered someone wrong, I apologize
post #37 of 42 Old 04-17-2012, 05:08 AM
Timo_90xj
Timo_90xj's Avatar
There are two dofferent planateries for both 231 and 242 - straight cut and helicat cut. Design change was around 1994 or so. I can't remeber if the input gears interchange between 231s and 242s with similar gear cuts - they may very well be different - but the yokes are exactly the same 1310 series so same DSs can be used.
Also, input gears can be changed, so depending on which spline count you have on the tranny output, you choose the input gear based on that. Keep in mind this as well:
* there are three different input shaft lengths used on Jeeps with 231 or 242
* there are different thicknesses for input gear bearing size, so the precision machined length for bearing mating surface can be different
* there are two different gear cut styles on the Jeep 231s and 242s
post #38 of 42 Old 04-17-2012, 06:19 AM
jpndave
There are indeed two different angles/profiles on the helical gears in these transfer cases at the break you specify. Neither are straight cut. The earlier 207/208 are straight cut but all of the 231/242 are helical cut. Gears interchange through all the different transfer case models (except the 241OR Rubicon case) of similar year (angle) and bearing width (there is another exception here on the later 241J JK case which uses a wide bearing). Early gears use the wider bearing and later gears the narrow. So, if you are doing some swapping and the the bearing widths don't match, that is a red flag that your helix angles are different. There are three different lengths. To my knowledge, the only interference problem is the AX15 which will sometimes hit with a long input gear. The shorts will sometimes miss the seal in the adapter.
HTH,
Dave
jpndave is offline
post #39 of 42 Old 01-17-2013, 10:25 AM
RainShadow
Command vs Selec Trac
Question:
COMMAND TRAC = NP 231
SELEC TRAC = NP 242
NP231 sits higher = more ground clearance
ARE THESE CORRECT ???
Thanks , Randy
RainShadow is offline
post #40 of 42 Old 01-17-2013, 11:21 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Originally Posted by RainShadow
Question:
SELEC TRAC = NP 242
Thanks , Randy
Those are correct
1990JEEPXJ is offline
post #41 of 42 Old 05-28-2013, 08:11 PM
xj_96_FP
here's a question, i have a 96 with a 242 with sye kit that was flooded by Sandy, i bought a 2000 stock with a 231, and want to swap everything over, can i swap with out mods or do i need to change anything?
xj_96_FP is offline
post #42 of 42 Old 06-17-2013, 11:44 PM
Vassago
Yes, you can. You need to swap the linkage and bezel too. There's a write-up
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD:
My Photography
Vassago is offline
np231 vs. np242 budgetHERO XJ Cherokee Technical Forum 18 02-02-2011 06:08 PM
NP231->Np242 lrsmithwhaley XJ Cherokee Technical Forum 2 09-18-2009 11:38 AM
Does NP242 use same SYE as NP231? RedZeppelinXJ XJ Cherokee Technical Forum 3 09-14-2009 02:04 PM
NP242 vs NP231 Zjeeplover XJ Cherokee Technical Forum 7 12-09-2008 03:43 PM
Np242 to NP231 XJIceQueen98 XJ Cherokee Technical Forum 18 08-29-2006 08:15 PM
