np 231j transfer case - JeepForum.com
post #1 of 9 Old 03-03-2012, 03:16 PM Thread Starter
kimjose1518
I just pulled the tcase out of a 89 xj and was going to put it in my 92 xj but the connectors for the spodometer and light indicators are diffrent. Can anyone help me out how to change them?
kimjose1518 is offline
post #2 of 9 Old 03-03-2012, 03:54 PM
Rytari
1991 XJ Cherokee
only connectors in it are different? what trans you got there, just thinking that input axle spline count...
for the wiring, just change that light switch and speedometer drive from your old tc
Rytari is offline
post #3 of 9 Old 03-04-2012, 09:08 AM Thread Starter
kimjose1518
Well the speedometer cable screws into the transfer case out of the 89. My 92 has 2 electric plug ins. The 89 has 4 vacuum lines that plug into it.
post #4 of 9 Old 03-04-2012, 03:35 PM
Rytari
1991 XJ Cherokee
vacuum lines are for disconnect type d30 front axle... your 92 dont need those either...
Rytari is offline
post #5 of 9 Old 03-05-2012, 04:55 AM Thread Starter
kimjose1518
How do I hook up my speedometer on my 92 to that transfer case?
post #6 of 9 Old 03-05-2012, 06:54 AM
Rytari
1991 XJ Cherokee
look the picture above, take out 89s speedometer cable rotating unit and change electric sender and gear from your old one, just small "spring plate", (little similar than distributors have) holding that down...
just notice that sender and gear are not centered in the plug, there is some slots on top of the cap where spring plate lids go an hold it in position
look how it is fitted in old case and assemble in same position in new case to maintain tooth contact for the gear...
Rytari is offline
post #7 of 9 Old 03-05-2012, 06:55 AM
Rytari
1991 XJ Cherokee
and still asking... what transmission you got?
Rytari is offline
post #8 of 9 Old 03-06-2012, 06:00 PM Thread Starter
kimjose1518
its a automatic transmition
my big problem is that I bought it with no transfer case so I dont have any old parts and I am going in blind here lol
post #9 of 9 Old 03-07-2012, 03:19 AM
Rytari
1991 XJ Cherokee
aw4 ? just remember that in those, output shaft spline count changes from 21 to 23 splines with H.O engine.
so 89 transfer case input wont fit to 92 automatic trans
also transfer case behind some amnual gearbox wont might not fit... but if you have that automatic also from older one it should be fine.
Rytari is offline
np 231 , transfer case , xj
Greasing slip yoke on 231j transfer case output shaft? KMason XJ Cherokee Technical Forum 12 02-19-2012 12:49 PM
231J transfer case from a YJ? will it fit into my 89 cherokee? rppngears91 XJ Cherokee Technical Forum 1 07-24-2009 12:08 PM
Difference between 231 and 231J transfer cases Brittlee17 XJ Cherokee Technical Forum 6 07-16-2008 04:55 PM
Will a 89 231j fit a 96 231j t-case? aj4x4truck XJ Cherokee Technical Forum 9 11-29-2006 03:02 AM
What Transfer Case... BrianXJ XJ Cherokee Technical Forum 2 06-28-2004 03:28 PM
