now that I got a Daily driver.... - JeepForum.com
post #1 of 8 Old 02-11-2008, 06:20 PM Thread Starter
taseal
1993 XJ Cherokee
its time for me to start working on my XJ.
I have few questions to start with.
I'm going to do a 3" lift. but before anything (the 1st mod) will be BFG MTs. I'm going to put 31s on there. I Know they will rub with stock suspension on u-turns and full flexes, but how bad is it? I mean driving in straight lines can't be THAT bad right?
what is the stock clearance with 31x10.5 tires? (i know the patriot is 9 with the trail rating package)
what about stock water fording? I know patriot is 19 on the trail rated version.
just wanted to know these few things
thx!
'93 Cherokee "XJ" Sport - 4.0 HO - 4x4 - AX15 - Chrysler 8.25 - Fun Jeep
'08 Patriot "MK" Limited - 2.4 - 4x2 - CVT II -DD Jeep
taseal is offline
post #2 of 8 Old 02-11-2008, 06:36 PM
severous01
severous01's Avatar
i had 31's and stock for the longest. only on full flex in the rear only, and full turns did i have a problem. and it wasnt bad, not like ripping apart my tires or anything. just some slight rubbing. and you can adjust the bumpstops for clearance. turning bumpstops are on the knuckles, and the rears you can add plates or rubber to compensate.
but, for the price of a 3" lift i'd just go that route. it's only 500 bucks, and you can get some decent ford rims from the junk yard with 31's on it for 200 bucks and go from there. there are tons of explorer/rangers out there running a 31. or, get some spacer/adapters and go for the f150/bronco wheels/tires.
any way. i dont know clearance numbers for crawling, but mud was never a problem for my xj, even stock. but, i'd aussie the front at least, and if possible and you know what you're doing, ford 88 the rear with a lsd.
severous01 is offline
post #3 of 8 Old 02-11-2008, 06:42 PM
Jeep9717
Your going to rub driving straight with the 31's, unless you want to trim the fenders. Id wait until you can get the 3" lift unless you want to throw some pucks and shackles in there temporarily.
If you have a DD, why not build it up a little more now, your going to end up doing it in the future anyways, even if you say you aren't. Jus my
97 Cherokee Country
4.5" homebrew lift--31" Baja Claws
Jeep9717 is offline
post #4 of 8 Old 02-11-2008, 06:48 PM Thread Starter
taseal
1993 XJ Cherokee
hmm... 2 contradicting things about the tires here.
I just want to be able to at least go into some muddy stuff before I can afford the lift. thats why I figured I get the tires now, and wait for the lifts for another month or two.
as far as building like crazy goes... I always like to have the car so that it is comfortable on the street.
I used to have a 700rwhp trans am, but it still had AC, cd player, and comfortable enough to take on the street and have a conversation inside
taseal is offline
post #5 of 8 Old 02-11-2008, 10:35 PM
collkid
My Friend Runs 31's with almost no issues at all.. you'll be totally fine
2000 Jeep Cherokee. 4.5', Long arms, Bumpers front and rear, Winch.
1992 Toyota Paseo DD 35+ MPG
Colorado Member #89
collkid is offline
post #6 of 8 Old 02-12-2008, 10:17 AM
itsge0ff
I had 30x9.5 tires and wheels with 4 inch backspacing before I got my lift and I rubbed like a mother on bumps turns anything. I trimmed up under my fender flare on the back and the front bumper cap to stop rubbing. The sound of tires rubbing is BRUTAL.
I would definitely say with stock rims my tires wouldn't have rubbed as bad on the fenders.
BUT with a 10.5 inch wide tire you might rub on the control arms with stock rims but prolly wont rub that much on the flares.
1999 Desert Sand Cherokee Sport with some cool stuff
itsge0ff is offline
post #7 of 8 Old 02-12-2008, 02:12 PM
mall_crawler
x2 on that, a friend of mine also has no problems
[ ] lllllllllll [ ]
The Trail Never Ends.....
mall_crawler is offline
post #8 of 8 Old 02-12-2008, 02:49 PM
Trekman8
Just because someone you know does not have any issues, DOES NOT MEAN he will not run into any. There are a lot of factors to consider, sagging for one.
1998 Jeep Cherokee Limited Black
4.0L......AW4 Trans......NP231 SYE......DANA 30 in Front......Corp 8.25 in Rear
RE 3.5" SuperFlex, Bushwacker Flat Flares and 33" Goodyear Wrangler Duratracs
Black XJ on Moabs Club Member #2
Trekman8 is offline
My daily driver. jbarr2000 XJ/MJ Cherokee Non-Technical Forum 12 05-25-2009 09:12 AM
got a daily driver Bobandbeans XJ/MJ Cherokee Non-Technical Forum 7 09-05-2008 07:48 PM
had to get a daily driver iwishihad1 XJ Cherokee Technical Forum 44 02-04-2008 06:13 PM
My new daily driver jeepman75 XJ Cherokee Technical Forum 26 10-28-2005 11:22 AM
still a daily driver? 4x4life XJ Cherokee Technical Forum 10 06-22-2005 12:09 PM
