Not your typical driveline vibe. - JeepForum.com
post #1 of 7 Old 07-23-2012, 07:10 AM Thread Starter
Zjeeplover
1995 XJ Cherokee
I'm getting vibes at almost all speeds. I do have an SYE and am running an Adam's Offroad DC rear shaft. It's not in the diffs, pinion angles, driveshafts are good, and joints are good. Tires, wheel bearings, etc have been ruled out as well. All this has been verified by Essentially Offroad. No trouble with shifting at all. It's a high frequency vibe. I'm thinking it's in the trans or TC. Anyone had a similar problem? Suggestions?
Zjeeplover is offline
post #2 of 7 Old 07-23-2012, 11:02 AM
sAe23
1995 XJ Cherokee
Is this a new, out of the blue, symptom, or did it happen right after installing the SYE?
Have you tried driving w/o the rear (or front) shaft?
Have you MEASURED the angles? What are they?
I was vibration free before installing my SYE. Now I get mirror shattering vibes above 60mph (70, after installing shackle relocation brackets. Have not re-measured angles yet).
Angles are good, tires balanced. No vibes w/o rear shaft. It's been balanced and rebuilt.
Still need to verify runout on pinion and transfer case but there is no visible sign of a problem there...
sAe23 is offline
post #3 of 7 Old 07-23-2012, 11:10 AM Thread Starter
Zjeeplover
1995 XJ Cherokee
It started after installing a poly trans mount, which has now been replaced with an OEM rubber mount. I installed the SYE and my shackle relocation brackets on the same day. I can't remember the pinion angle but I did measure it with an angle finder and have had two shops tell me my pinion angles are perfect. I've driven w/o the front and rear shaft, separately of course. Still had vibes.
post #4 of 7 Old 07-23-2012, 12:04 PM
larjerr
Does it change immediately after letting off gas or accelerating?
larjerr is offline
post #5 of 7 Old 07-23-2012, 07:30 PM Thread Starter
Zjeeplover
1995 XJ Cherokee
No, it's consistent throughout acceleration, deceleration, and coasting.
post #6 of 7 Old 07-24-2012, 02:07 AM
sAe23
1995 XJ Cherokee
Well then, either both your shafts need rebuilding, or it's the tires or something else
sAe23 is offline
post #7 of 7 Old 07-24-2012, 06:57 AM
Pats94
If it wasn't vibrating before, I'd really inspect the hell out of those 3 items. Have you looked at that sye for run out and the yoke?
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
ax15 , driveline , np231 , vibes , vibrations
Bad driveline vibe + noise Green01XJ XJ Cherokee Technical Forum 3 02-02-2012 07:09 AM
Need help with rear driveline vibe ikenchute XJ Cherokee Technical Forum 23 07-31-2010 04:15 PM
another driveline vibe question nhlnms XJ Cherokee Technical Forum 2 11-03-2008 03:10 PM
stock driveline vibe Absolutexero XJ Cherokee Technical Forum 4 07-15-2008 06:08 PM
Typical ... 8.25 ... no d44 LOCKED UP XJ Cherokee Technical Forum 16 07-08-2003 11:23 AM
