A not so budget boost - JeepForum.com
post #1 of 17 Old 11-28-2006, 07:51 PM Thread Starter
jeeper01
I have been thinking about a lift for my newer cherokee, I have taken in mind my other one is ready to be built has her longarms, and some things sitting in the garage. I am looking for 2-2.5" of lift. The OME is very nice but I don't have 900$ to spend on a 2" lift. I prefer RE just because of the reliability and the stress I have seen them take, also the color matches my stickers, but do they have any smaller spring besides the 3" to fit on an XJ? If not does anyone sell just OME coils. Then I got to thinking about tires and wheels... Are wheel spacers any good it would give me what I need, also tires it says 30x9.5 but I have seen 30x9.5 on a stock setup, what is the beefiest tire size I can go? Thanks for the help!
1998 Cherokee Classic... 2" BB on Moabs
1988 Cherokee Limited... 4.5" RC lift, RK longarms, on 31's. Several homemade skids.
jeeper01 is offline
post #2 of 17 Old 11-28-2006, 08:11 PM
Cerealdaemon
1988 FSJ Wagoneer
there are lots of places that you can look for that kind of stuff, check Quadratec to find some front springs in anywhere from 1 to 6 inches of lift.
there are more companies that do lifts other than OME and RE, do some shopping and look around
"stand over and deliver, or the Devil he may take ya!"
Cerealdaemon is offline
post #3 of 17 Old 11-28-2006, 08:12 PM
GottaBeJeep
It's a lot of reading, but check it out, and be sure to read all the updates and links. Might point you in the right direction:
http://www.rocklizardfabrications.co...dget_boost.htm
...Off Road Armor that's "Tough as Scales"
GottaBeJeep is offline
post #4 of 17 Old 11-28-2006, 08:13 PM
fufanu360
what a bout a black diamond 3 inch, i think theyre cheap
fufanu360 is offline
post #5 of 17 Old 11-28-2006, 08:23 PM Thread Starter
jeeper01
What about TJ coils I have been doing more research if I use a 3" TJ coil it should net 2.5" right?
jeeper01 is offline
post #6 of 17 Old 11-28-2006, 08:34 PM
AznDrgn
I'm using 4.5" TJ coils and they come out around 3.75-4" but I haven't driven it to settle them in yet.
'87 Jeep Cherokee Laredo 4.0L, NP231, AW4, 5.5" lift, s10/waggy/XJ bastard pack, 7" fabtech TJ coil springs - Weekend play thing
'83 Porsche 944 2.5L Callaway turbo - Daily driver
'81 Porsche 924 - Custom EFI and forced induction project
'83 Porsche 944 2.5L - Sold
'78 Porsche 924NA 2.0L - RIP
AznDrgn is offline
post #7 of 17 Old 11-28-2006, 08:43 PM
conrasm
conrasm's Avatar
Rusty's just came out with a 2" lift that uses coils and AAL's, but for the price, I think you'd be better off doing your own budget boost the with the ZJ front coils from carquest and adding some XJ or S-10 leafs to your pack.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #8 of 17 Old 11-28-2006, 08:45 PM
Cerealdaemon
1988 FSJ Wagoneer
the ZJ coils (stocks from a V8 magnum) only net like 5/8ths to 1 inch total. IMO, they aren't worth it.
post #9 of 17 Old 11-28-2006, 08:54 PM Thread Starter
jeeper01
Now I am looking for more info on TJ coils, Rubicon express states the re1300 and re1363 are roughly the same. the part numbers are on both the TJ and XJ page. I am looking for 2-2.5" of lift perferably without spacers.
jeeper01 is offline
post #10 of 17 Old 11-28-2006, 09:56 PM
webqaz
Just remember that if you go 3" + you may have to get an SYE to deal with vibrations.. I have been crunching the numbers for an SYE for the past few days.
webqaz is offline
post #11 of 17 Old 11-28-2006, 10:00 PM
conrasm
conrasm's Avatar
About the cheapest way to do it is...
If you have older style NP 231, do the PORC SYE and front DS combo. Should be under $250 for everything.
If you have the newer style TC, then hack 'n tap and front DS can probably be done for $200.
Shawn
conrasm is offline
post #12 of 17 Old 11-29-2006, 05:19 AM Thread Starter
jeeper01
I am not going over 3" I am not worried about an SYE, I have a Jeep sitting at 4.5" without a tc drop or a SYE. Just shims.
jeeper01 is offline
post #13 of 17 Old 11-29-2006, 06:20 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I'd say go to the dealer and ask about the ZJ V8 equipped Up Country springs:
Per a online article:
52088363 Code GN front springs $31.69each
These have a stiffer ride, but not bad. That should also put you in the 1" of lift catagory. Throw on a 1" or 1.75" coil spacer and you should be in the 2-2.5" range.
HD rear leafs and a shakles or a Hybrid pack set (rocklizard setup) should eaily net around 2-2.5" and that setup will outlive a AAL set.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #14 of 17 Old 11-29-2006, 08:12 AM
badron
Lifts are NEVER cheep. Because once you have lifted you are hooked. Then bigger tires then skids and bumpers. Lift=drugs. Stop now If you can before it's to late. Before you sell your sole to SATAN for one more inch of lift.
Quick, place your right hand on your FSM and repeat after me. I will not lift my Jeep. I will not lift my Jeep.
badron is offline
post #15 of 17 Old 11-29-2006, 08:47 AM
XJ99
XJ99's Avatar
2006 XK Commander
If this is your DD.... Wait, if this is your familie's main source of transporatation then I think the OME stuff is worth it. At DPG the 2" kits are $759.00, and the 3" kit is $779.00.... http://www.dpgoffroad.com/XJ_OME_Kits.htm The ride is great, and the flex is awesome. Also look at what you get. New coils, leaf springs, shocks, and JKS quicker discos. BTW, I highly recommend the 3" kit for $20 more.
After doing all the research the OME kit really wasn't that much more than others out there.
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline
Budget Boost For My XJ jlmxj XJ Cherokee Technical Forum 9 01-20-2008 10:20 PM
Budget Boost? TJted33 XJ Cherokee Technical Forum 8 07-09-2006 09:46 AM
budget boost jaredakleiman XJ Cherokee Technical Forum 8 11-26-2005 02:18 AM
Budget Boost DVM04 XJ Cherokee Technical Forum 5 04-29-2004 04:51 PM
What gives? Help with RE budget boost... NotMatt XJ Cherokee Technical Forum 6 01-03-2004 11:27 AM
