Not a normal crank story - JeepForum.com
post #1 of 8 Old 09-08-2013, 12:18 PM Thread Starter
Thd
First off i have a 98 cherokee sport 4.0 So many problems with my cherokee. First it starts the no start issue after I drive for awhile I messed around with some fuses and relays things like that and it stopped for a couple days, then it started cutting out and stalling really bad i couldn't get over 10mph and it wouldn't shift so i swapped computers with a 99 cherokee and it ran perfect for about a month then started the no start agin i changed to tps and it stopped for a day or 2 started again then I changed the cps and cam sensor the no start issue is now fixed but it has a really tough idle after components under the good get hot runs perfect for about a 15 mile drive and pulls up and intermittent loss if cam and crank sensor the longer it runs the worse the rpms jump around and cuts out pleaseeeee helpppppp meeeee I love my xj!!!!!
Thd is offline
post #2 of 8 Old 09-08-2013, 12:25 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Are you using genuine Jeep repair parts or crappy Chinese "Lifetime Warranty" parts ?
Are ALL of your tune parts fresh, including the coil ? Have you cleaned the Throttle Body and Idle Air Controller recently ?
How old are your O2 sensors and have you tested them for correct functioning ?
CJ7-Tim is offline
post #3 of 8 Old 09-08-2013, 01:01 PM Thread Starter
Thd
Everything from advance auto I've thought about buying genuine mopar after reading everyone else's threads but didnt want to spend that money unless I thought it was a for sure thing i couldn't find any other threads EXACTLY like mine
Thd is offline
post #4 of 8 Old 09-08-2013, 01:04 PM Thread Starter
Thd
Cleaned the throttle body but not the IAC everything else is new, it almost seems like it gets so hot under my hood everything just goes to crap because its a little extreme although it dorsnt get "temperature hot" I can barely touch the computer it will sizzle your fingers just about
Thd is offline
post #5 of 8 Old 09-08-2013, 01:22 PM
CJ7-Tim
CJ7-Tim's Avatar
Cheap crappy "Lifetime Warranty" parts are often out of specification, or even failed, right out of the box. Many times they have a short service life before they fail. Always buy top quality replacement parts and genuine Jeep sensors. Numerous threads detail long and frustrating searches for a "problem" that ended up being cured with genuine Jeep repair parts.
Cheap parts are cheap for a reason.
CJ7-Tim is offline
post #6 of 8 Old 09-08-2013, 01:42 PM Thread Starter
Thd
Cleaned the iac, drove it for the first time in a couple days and now I have codes p1491 p1492 p1694 and p1391 I will replace the sensors tomorrow if the dealer has them in stock and let you know if that fixes the problem
Thd is offline
post #7 of 8 Old 09-10-2013, 09:57 PM Thread Starter
Thd
The mopar crank sensor fixed it haha thanks man
Thd is offline
post #8 of 8 Old 09-11-2013, 11:08 AM
CJ7-Tim
CJ7-Tim's Avatar
CJ7-Tim is offline
cherokee , jeep , xj
