Not downshifting after stopping - JeepForum.com
post #1 of 3 Old 09-15-2007, 06:24 PM Thread Starter
NUBOPOLY
I am posting this for a friend.
If there has been a post about this before excuse me but the new search feature isn't as good as the old one and I wasn't able to find anything.
He has a 98 Cherokee with the 4.0L with about 195000 miles on it. We started to have problems a while ago with rough idle and the car randomly down shifting, so we figured it was the TPS, replaced that and the problems went away, well a short while later he started having problems with the car not down shifting at lights and also when he goes to pass, it will down shift into 3rd but not 2nd(say if he goes WOT at 45MPH, it will not go down into 2nd, just 3rd).
So today we had the codes read and we got
P0700 Trans Control Sys Malfunction(thinking it was caused by the shift solenoid code)
P0758 2-3 Shift Solenoid Circuit Electrical
P0756 2-3 Shift Solenoid Valve Performance - No First or Second Gear
P0705 Trans Range Switch Circuit(thinking it was caused by the shift solenoid code)
P0171 Bank 1 Lean (We were thinking o2 sensor)
So my question is, could I be right about the 700 and 705 being caused by whatever is causing the 758 and 756? and what could be causing the 758 and 756, If you guys need any more information just ask. Also, am I correct about the 171 code most likely being the front o2 sensor?
NUBOPOLY is offline
post #2 of 3 Old 09-15-2007, 08:58 PM
BlkBird
Wow, all those tranny codes and 195k. I cant help but that would have me worried, might be time for a rebuild.
2004 Wrangler X 4.0
2000 Cherokee Sport 4.0
1992 Dakota Sport 5.9
1971 Pontiac Firebird
BlkBird is offline
post #3 of 3 Old 09-15-2007, 09:38 PM Thread Starter
NUBOPOLY
Yea, sadly we try not to think about that though. Although we also have to consider that ignoring a rebuild 100% and trying to find only ways around it could cost him also.
NUBOPOLY is offline
downshifting issue Ibjeepn83 XJ Cherokee Technical Forum 5 07-19-2007 02:39 PM
Tranny Downshifting Question mrobertson XJ Cherokee Technical Forum 1 06-04-2007 07:35 AM
Question: Downshifting into 12 Tybombero XJ Cherokee Technical Forum 5 03-31-2007 11:16 AM
Intermittent downshifting problem TristanXJ XJ Cherokee Technical Forum 5 09-20-2004 05:46 PM
