Is this normal? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Is this normal?
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 02-07-2007, 10:08 PM   #1
XJK
The Guru of Nothing
XJK's Avatar
Is this normal?
so i turned on my ari conditioning today for some wierd reason and i heard a loud screaching sound from the engine compartment, this only happened when i turned the ac all of the way up and went away after about 2 minutes, is this a big issue?
thanks
-kyle
XJK is offline   Reply With Quote
Unread 02-07-2007, 10:22 PM   #2
Goldenknob
1992 XJ Cherokee
sounds like your belt is loose. see if it's cracked or worn you may need to replace it or just tighten it.
Goldenknob is offline   Reply With Quote
Unread 02-08-2007, 07:26 AM   #3
groovyone
1998 XJ Cl***ic
groovyone's Avatar
Yep, what they said. Mine did the same thing, and I fixed a bunch of stuff that didn't need fixing. The belt was just loose. I thought it was tight after I replaced it, but it wasn't tight enough!
"The difference between genius and stupidity it that genius has its limits."
groovyone is offline   Reply With Quote
Unread 02-08-2007, 08:06 AM   #4
bee guz
I could be just a little loose, or something got on it a little oil or something, It's a good practice to run you A/C a little in the winter to keep the oil circulated in the comprssor..
bee guz is offline   Reply With Quote
Unread 02-08-2007, 08:34 AM   #5
Atari.fan3000
Yeah 2x loose belt
98 XJ SE 4.0 L White 70,xxx miles RE 3.5in Super Flex Lift, BFG AT 32x11.5x15; adj Control arm, RE gen2 disco's, T-case drop
Factory Front Skid/ TC Skid/ Gas Skid; Cobra 18 WX ST II SoundTracker CB 3 FT firestick mounted on RoofRack;
Set of BaJa lights top bumper mounted; Light bar/w 150watt KC DayLighters ;Rusty's Air intake; FM Delta 50
C 4X4 front tow hooks; Rear Hatch Speakers; Painted Fenders Flares; herculined floor; Back-Up lights inside bumper
My car Domain Page
Atari.fan3000 is offline   Reply With Quote
