NooB here. Buying an XJ - JeepForum.com
post #1 of 28 Old 06-16-2005, 10:46 AM Thread Starter
HiJinx
I'm in the market for a Cherokee and thought I should stop in here to get some advice from yall on what to look for when looking at XJs.
Thanks much guys 'n gals.
HiJinx is offline
post #2 of 28 Old 06-16-2005, 11:44 AM
ChaoticBastard
Thats a pretty broad question..Well Miles on an XJ (if maintained) are not a big issue.Most XJ's 4.0's can go for 300k+ The aw4 Transmissions easily go 200k+ There are different transfer case configs and Rear and Front Axle setups.They are all good in my opinion.In the sticky threads you will find any and all info you need on an XJ.Read into them.You will find all the mods you can do etc etc.Buying an XJ was the best thing I have ever done.I have a 90 Wagoneer Limited with 89k.I love it!Good luck in your search and dont hesitate to ask any questions.
2009 Mustang GT Premium
2012 JK Sport
MetalHead Jeep Club Member #33
Originally Posted by kairo
what's wrong with bombing poor people? It has all the awesomeness of bombing combined with removal of crime. It's like a win win situation.
Unwad your panties
ChaoticBastard is offline
post #3 of 28 Old 06-16-2005, 12:12 PM Thread Starter
HiJinx
Ya, sorry 'bout the vagueness of that. I guess what I meant was, "are there any known issues I should be aware of and on the look out for?".
I'm mechanically inclined and have been building and racing watercooled VWs for years, have build and raced rails, etc, so, fixing anything isn't an issue. Just wanted to know what to keep an eye out for as far as known problems.
Thanks
HiJinx is offline
post #4 of 28 Old 06-16-2005, 12:20 PM
Shenck
Shenck's Avatar
Oil leaks:
The valve covers and rear main bearing seals on the I6 are common but easy to fix for most people.
Coolong:
XJs run hot (210*) so keep an eye on this. But reading your post this shouldn't be an issue.
Like it was said before the I6 is bullet proof if well maintained. Good luck in looking.
------ED-----
2007 Rubicon 6-Speed, 3" Lift with 35's
1993 Cherokee Country, 3" AAL. with soft 8's & 31's
Shenck is offline
post #5 of 28 Old 06-16-2005, 12:21 PM
ChaoticBastard
Im kinda a newbie when it comes to XJ's but I am mechanically inclined as well.From what I have gathered from my time on here Is the rear main seal leaking..and or the o ring leaked for the oil filter.Rear seal,Big messy job.But fixable.They are common problems.Blow By is another problem but totally fixable.Transmission wise like i said they are known to be very rugged transmissions.The 4.0 87-90 I believe is called a RENIX.then they went to the 4.0 HO..they both have there benefits,I have heard that the casting on the renix engine is stronger then that of the HO..Possibly making the renix last longer.The difference in HP between the 2 is 15hp..Im just throwing my 2cents in from what I have learned.My fiancee has a 95 XJ sport with 150k and it runs just as good if not better then my 90 with 89k.The only difference is her rear seal leaks and mine does not yet,lol..There are alot of folks(helpful) folks with alot more knowledge then me that will be more then happy to help you.Good luck.But it is an investment you definatly will not shed a tear over!
2012 JK Sport
Unwad your panties
post #6 of 28 Old 06-16-2005, 01:31 PM Thread Starter
HiJinx
What's a good price range I should look at?
And, are there radiator upgrades and/or oil cooler kits available. (Not really concerned about oil cooler kits, I can make my own if need be)
The reason I ask is I'm in Phoenix AZ.
HiJinx is offline
post #7 of 28 Old 06-16-2005, 09:50 PM
ChaoticBastard
well I got my XJ -1990 Wagoneer Limited.just like a cherokee..with 85k for 1000 bucks in near mint condition from a farmer.Thats Rare.The book on mine (low book) is 2,450.A 1994-1995 with around 100k-120k should be around 1600-2600 roughly,Thats PA prices.You can go older with some work from anywhere reasonable 800 bucks to 1400...These are prices I have seen around.I have seen XJ's with 200000k go for 1500 though.Depends on the overall condition..XJ's hold there value by far..My fiancee might be selling her 1995 XJ Sport All Stock 146k for around 1500.it needs a rear seal I believe and a good cleaning but runs like a tank.If we decide to sell it I will post i there good luck in your search!
2012 JK Sport
Unwad your panties
post #8 of 28 Old 06-16-2005, 09:56 PM
ChaoticBastard
hope this works.here are the links to the threads all about cooling
AUX FAN TEST WITH A JUMPER
http://www.fivezerofive.com/cpg132/...ls.php?album=81
INSTALLING NEW RADIATOR
http://www.go.jeep-xj.info/HowtoRadiatorFitting.htm
BURPING the COOLING SYSTEM
http://www.lunghd.com/Tech_Articles.../BurpAirMod.htm
CONVERTING THE CLOSED COOLING SYSTEM
http://www.geocities.com/chmwatson/...low-bottle.html
http://www.olypen.com/craigh/rad.htm
http://www.off-road.com/jeep/cherok...r/radiator.html
http://www.madxj.com/MADXJ/technica...ystemSwitch.htm
WATER PUMP REPLACEMENT
http://jeepin.com/features/waterpump/index.asp
OVERRIDE SWITCH ON ELEC FAN
http://www.olypen.com/craigh/auxfan.htm
2012 JK Sport
Unwad your panties
post #9 of 28 Old 06-16-2005, 10:58 PM
cmotsvt
Id go for a jeep that hasnt been modified or wheeled too much. Try and get a feel for how well it was serviced, get records if you can.
cmotsvt is offline
post #10 of 28 Old 06-16-2005, 11:22 PM Thread Starter
HiJinx
cool, thanks much guys. much help yall have been. I've only heard good things about jeep folk and am glad to find it true.
And yes, I'll be looking for a stock jeep driven by a soccer mom
I like to do all my own mods and such. Much fun to be had.
96 XJ Sport 4.0 auto
4.5" lift on 31s.
88 XJ 4.0 5 speed.
3" lift on 31x10.5 tires.
HiJinx is offline
post #11 of 28 Old 06-17-2005, 11:18 AM
ChaoticBastard
Yes I second getting a stock cherokee.Definatly..good luck again with your search
2012 JK Sport
Unwad your panties
post #12 of 28 Old 06-29-2005, 11:59 AM Thread Starter
HiJinx
Hey guys. Still looking for a jeep.
Can yall tell me a bit about 88s?
Also, does this seem like an OK deal?
http://www.autotrader.com/fyc/vdp.js...sp=y&cardist=3
4.5" lift on 31s.
88 XJ 4.0 5 speed.
HiJinx is offline
post #13 of 28 Old 06-29-2005, 12:20 PM
innocentman
personally i wouldn't, last year i got my '87 cherokee with 250,000 K on it and it was in fairly good shape...when i got it...and it was only apprasied for $900 avarage
1987 Jeep, Been in family since it was bought....totally f*ucked it up on last off roading trip, tore the fender flares off the front passanger side, lost the mirror off the front passanger side, did a nose dive into the ground pushing the engine back a few inches, breaking the motor mounts, ended up getting towed back from a bronco (now i feel unclean) and on the way back, accidently turned into a tree and took off the left rear quater panel
innocentman is offline
post #14 of 28 Old 06-29-2005, 12:30 PM
fryed_1
I got mine, 94 I6 5spd with 110k miles on it for $300. Had 3 or so inch lift already and some visual things done to it (I hate the hood scoops). Front end was wrecked as well, but cost me all of $125 in junkyard parts. Also took about 2hrs with a strap tied to a telephone pole to straighten it out. Engine runs superstrong though, and everything else is awesome. I love it.
http://phenix.rootshell.be/~bfrye/pics/94xj1.jpg
fryed_1 is offline
post #15 of 28 Old 06-29-2005, 12:33 PM
innocentman
lol, yea, the hood scoops make it look like a -=-=-=-=-= jeep thats drivin on road 24/7...but i'm pretty sure thats seen trails a few times
Jeep noob need help before buying 1990 comanche.. jamoka3 MJ Comanche Technical Forum 5 09-03-2008 09:51 AM
Noob from Chicagoland- buying a 99 2 door SE... phorty XJ/MJ Cherokee Non-Technical Forum 5 06-03-2008 02:07 PM
Noob To Forum and Noob w/ an XJ! norsky XJ Cherokee Technical Forum 19 03-04-2008 06:01 PM
noob Staffybull603 XJ Cherokee Technical Forum 3 11-07-2006 08:46 PM
Noob here with some Noob Questions... slver01XJ XJ Cherokee Technical Forum 6 04-14-2006 11:22 PM
