non-A/C idler pulley? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > non-A/C idler pulley?
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 09-12-2008, 08:08 PM   #1
nrpalmer32
1987 XJ Cherokee
So I searched around to find something on removing the a/c condenser and I did find something saying that if I remove the condenser then I have to put the stock non-a/c idler pulley, is that correct? and it has to be grooved right? well I was looking online trying to find one and was wondering if this is the correct one: Idler Pulley.
Here is a pic if it makes it easier for anyone that knows.
nrpalmer32 is offline   Reply With Quote
Unread 09-13-2008, 06:19 AM   #2
tangofox007
Did you mean a/c compressor? If so, you will need a pulley and a bracket to mount it to.
tangofox007 is offline   Reply With Quote
Unread 09-13-2008, 08:08 AM   #3
Saudade
1988 XJ Cherokee
You need an AC bypass pulley (with bracket). They're a bit had to come by for an 87 (87-90 should work) due to the way the bracket mounts. Why do you need to remove your compressor?
Saudade is offline   Reply With Quote
Unread 09-13-2008, 10:22 AM   #4
nrpalmer32
1987 XJ Cherokee
yeah my bad, i was wondering why no one was answering. haha well yeah i meant the compressor. so I also need a bracket to mount the ac bypass pulley to? and about removing the compressor, i am wanting to remove the whole a/c system since mine is leaking bad, and i dont want to pay the money to convert it and fix the leaks. I never really use the a/c in my jeep anyways so i figured it wont hurt that much to remove it and heard it should make it run a little easier.
Unread 09-13-2008, 11:04 AM   #5
nrpalmer32
1987 XJ Cherokee
So i see what your talking about now, I found one for a 91-93 that comes with the bracket. But I am guessing that it wont fit? Does anyone have any input on this? Maybe just a bigger/smaller belt to accomodate it?
Pulley with Bracket
Unread 09-13-2008, 11:54 AM   #6
Saudade
1988 XJ Cherokee
Correct, that one won't fit. The compressor bolts to the bracket using through bolts that are horizontal. The one above uses through bolts that are vertical. You could ty a few junk yards and see if you can either find the correct bypass, or maybe pull the AC bracket off the block from a 91-93.
As long as the clutch bearing is OK, you can leave the compressor on the engine. Just disconnect the clutch wire. Aside from carrying the weight, it won't really affect anything.
If the compressor is OK and your leak is elsewhere, many convert the compressor to on-board air so you can pump up your tires after leaving the trails.
Unread 09-13-2008, 11:59 AM   #7
Mr_Random
1986 XJ Cherokee
You would have to swap to HO brackets, and need a new alternator with that... and an external voltage regulator... then you'll be good!
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
http://www.jeepforum.com/forum/f22/86-xj-w-mpi-budget-re-build-757079/
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline   Reply With Quote
Unread 09-13-2008, 01:10 PM   #8
tangofox007
The easiest thing to do is unplug the compressor and forget about it. If the clutch bearing ever fails, it is easy to replace. If the compressor clutch is not engaged, the engine won't run any "easier" with the idler pulley.
Unread 09-13-2008, 01:17 PM   #9
That1guy
2007 WK
Thats what i was going to say.....
x2
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline   Reply With Quote
Unread 09-13-2008, 04:06 PM   #10
nrpalmer32
1987 XJ Cherokee
Hmmmmm.....well that sounds like a good idea too! Hey Thanks guys for all the help. i think i'll just try to disengage the clutch on the compressor then.! Thanks
