#1 | ||
Noise front right
#2 |
Could be the shock, could be the hub bearing ... if you have a lft & stock sway links it could be the swaybar hitting the spring too
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter. www.noeither.com |
#3 |
Broke Bogger
If its there bearing, you will see the wheel tilt a bit when parked on flat ground, also it may pull while driving or click when in motion.
I'd say its probably, hopefully the swaybar hitting the spring.
Matt __________________ 97 XJ - Black Sport, 4.0L AW4, D30 and 8.25 6" Skyjacker/RE, 33x13.5 Swamper LTB Cracked Frame, good for steering!!! MY XJ PICS |
#4 |
This sounds just like my problem, but on the left side. Can you let me know if you find out what it is? How can you tell if ti is the swa bar hitting the spring? Thanks ahead of time.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Front end noise | gawno1 | Cherokee Technical Forum | 2 | 05-24-2009 05:44 PM |
| Front End Noise | ginkod | Cherokee Technical Forum | 4 | 08-19-2008 10:33 PM |
| need help w/ front end noise | maddzz | Cherokee Technical Forum | 1 | 04-18-2008 10:27 AM |
| Front end noise? | linkovich | Cherokee Technical Forum | 27 | 11-27-2007 08:48 PM |
| A little front end noise | sayit | Cherokee Technical Forum | 1 | 12-01-2004 07:43 AM |
The time now is 11:36 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
