Quantcast Noise coming from driver side...exhaust leak? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Noise coming from driver side...exhaust leak?
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 07-29-2008, 05:13 PM   #1
lyleorszulak807
1988 XJ Cherokee
Hello,
Well as usual by replacing something another problem appeared. So I finally replaced the motor mounts on my jeep. There was no rubber left and the engine rattling was a little annoying at stop lights. When I started her up I noticed a louder noise than usual and she idled like crap. On a 40 mile freeway trip I noticed that I had no low-end power and the motor vibrated more and was loud. First thing that I could think of was exhaust leak. Reasons:
1) Before I fixed the motor mounts, they were so bad that I heard noise while driving from the exhaust pipe banging on the transfer case cross member. This could of caused a small crack/leak but I never experienced a
2) While installing the new motor mounts I had to life the engine couple of inches from where it was sitting in order to line up the bolts. In doing so may have opened up the crack/leak.
Question: What do you guys think?? I took a glance under neath and didnt see any gaping holes. I had a small leak on my YJ once but never felt this much power loss. Also ive looked around for a new header, pace setter is junk. any other brands fir the 89 year? Dont see alot of applications for the renix engine.
Thanks,
Lyle
lyleorszulak807 is offline   Reply With Quote
Old 07-29-2008, 05:15 PM   #2
lyleorszulak807
1988 XJ Cherokee
I did have to remove the oil pump on the pass side to remove the motor mount bolt. I dont think this could of caused what is happening because my oil pressure seems ok, 40-60 psi depending on acceleration.
Lyle
Old 07-29-2008, 09:17 PM   #3
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
I would look for a vacuum leak. Did you remove the air cleaner housing to reach the driver side? Not sure of your year but my 1990 has a vacuum manifold of the drivers side and you could had knocked something loose there to cause a power issue. The noise is probably exhaust leak since it is a common flaw on the I-6 to crack I think mine was around the #5-6 exhaust port.
Here is a link to a manifold seller. You can probably find a better deal than this $219 stock style header.
http://www.quadratec.com/products/product_search.php?cv=1000&cn=Headers&c=76&pg=1
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
Jeep Pic's
coppertop71 is offline   Reply With Quote
Old 07-30-2008, 02:17 PM   #4
lyleorszulak807
1988 XJ Cherokee
Started the Jeep today and everything is running fine now. I think the engine knock sensor somehow retarded the timing causing it to run like crap. As to why the knock sensor was doing this....I don't know.
Lyle
Glock Forum
