No turn signals/wipers/radio on '92 XJ LTD - JeepForum.com
post #1 of 23 Old 06-05-2007, 10:57 AM Thread Starter
OR Transplant
1992 XJ Cherokee
I purchased a '92 Cherokee Limited from a friend back in Feburary.
My first Jeep and I'm loving it.
Just about a week ago, I started it up after leaving it parked at the airport while on a trip for 4 days and while it started fine, I had no turn signals or winshield wipers and the radio only comes on if I've had the brake pedal pressed for 3 or more seconds.
Additionally, if after pressing the brake pedal I try to turn on the signal or wipers before the radio clicks on, the radio remains off.
I've checked and replaced the related fuses and circuit breakers (that 5.5 amp CB is a pain in the butt to find...) Have not checked the relays under the hood yet, but according to the manual, there doesn't really seem to be anything in the distro area related to these issues.
The only related modifications are that the radio/CD deck is not stock, but is an aftermarket Pioneer and was working fine previously.
No one really uses their turn signals in Nashville anyway, so that's not a serious problem - but no radio and no wipers is getting really annoying - especially with summer thunder storms now rolling in.
Any ideas?
OR Transplant is offline
post #2 of 23 Old 06-05-2007, 11:00 AM
jv3kxj
I'd have the battery load tested, and the alternator tested.
Signature
jv3kxj is offline
post #3 of 23 Old 06-05-2007, 11:09 AM Thread Starter
OR Transplant
1992 XJ Cherokee
My understanding was that the alternator was recently replaced before I purchased it and I had the battery tested shortly after purchase.
However, recently I've also watched the voltage meter randomly sit above and below 14v. after start-up with no real rhyme or reason...the fact that it is sometimes above 14v seems to me that the alternator is still charging the battery with some regularity. Am I wrong?
Is there something else I should check?
post #4 of 23 Old 06-05-2007, 01:07 PM
NinjaofDoom
1990 XJ Cherokee
I have a similar prob with mine. The turn signals, wipers, and heater blower do't work. I figured out it was a short in my ignition switch because if i push up and have way turn the key off they all come on.
NinjaofDoom is offline
post #5 of 23 Old 06-05-2007, 05:52 PM Thread Starter
OR Transplant
1992 XJ Cherokee
Ninja-
Do your signals/wipers/fan etc... stay on if you start up that way?
If so, it sounds like the fix is a new ignition switch???
post #6 of 23 Old 06-06-2007, 07:45 PM Thread Starter
OR Transplant
1992 XJ Cherokee
Bump for more advice
post #7 of 23 Old 06-10-2007, 10:44 AM Thread Starter
OR Transplant
1992 XJ Cherokee
Update:
guys at auto parts store said that battery/alternator not likely cause, but to try replacing the relays.
The AC also is not working - so I'm wondering if this is at the root of the problem - and if replacing the AC related relays might do the trick for everything.
In the mean time, I've checked EVERY fuse - inside and under the hood. All are good.
Any thoughts?
post #8 of 23 Old 06-10-2007, 01:47 PM Thread Starter
OR Transplant
1992 XJ Cherokee
Not the relays. I replaced the AC and Starter relays with no change.
So, now I'm thinking I have a short, ground problem, or bad wiring harness somewhere.
Do I try this myself or take it to the dealer? How much can I expect to pay for this at the dealer?
post #9 of 23 Old 06-10-2007, 04:40 PM
scorpio18
Try re-seating the black plug on the left hand side of your steering wheel, it controls all of those items. It sometimes feels like its all the way in, but you have to use a socket set to get it really seated well.... You have to remove the cover with a torx T10 screw driver
scorpio18 is offline
post #10 of 23 Old 06-10-2007, 06:47 PM Thread Starter
OR Transplant
1992 XJ Cherokee
I'll give that a shot tomorrow. Thanks for the tip!
post #11 of 23 Old 06-10-2007, 07:27 PM
kg4kzv
1995 XJ Cherokee
I just replaced my ignition switch 2 days ago because my Jeep would shut down as soon as I released the key from the start position. I thought it was something more serious but then I noticed I had no turn signals,blower motor,radio or wipers. I could wiggle the switch and make things work sometimes the engine would stay running but nothing else would work other times I lost the engine but everything else would work. New switch fixed it right up. But I wanted to know how the switch failed so I took it apart. Inside I found one of the contacts a long bar had been over time building chard deposits and heating up to the point it melted through the plastic switch housing. It is a ground for the whole switch so it has a big load on it. Just wanted to explain why I'm with those saying check your ignition switch.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #12 of 23 Old 06-11-2007, 09:41 PM Thread Starter
OR Transplant
1992 XJ Cherokee
O.K., so this morning I looked all over for this "black plug" to no avail. Where is this thing? I removed the cover below the dash...looked all around the steering wheel/collumn...don't see anything that applies.
Unfortunately, my account is too new to post pics...
Help, anyone? I'm pretty new to all this - and work too much to go to a dealer; although I may have to resort to that...
post #13 of 23 Old 06-11-2007, 10:31 PM
scorpio18
To get to it; you have to take off the plastic cover on the steering column. The black plug is right behind the turn signals on the left of your steering wheel. You could have a different setup then me, but thats where mine is...
post #14 of 23 Old 06-11-2007, 11:16 PM
RickyN29
RickyN29's Avatar
Definitely the ignition switch.
The wire will be coming from the ignition switch (a large gauge BROWN wire) and will lead down to a PDC on the knee bolster.
Replace the ignition switch and call me in the morning.
1990 XJ Laredo 4x4 Auto
*Rusty's ~6" Lift
*Dana30/Dana44 3.55's
*Pacer Wheels/High-Tec Retreads 31" MT
*KargoMaster Safari Rack
*CSF Open Cooling System Conversion
*Hayden Tranny Cooler
*Flowmaster 40 Delta & High-Flo Cat
*PORC SYE / FRT DS Combo
*The Doors are off again for summer!
RickyN29 is offline
post #15 of 23 Old 06-20-2007, 04:44 AM
Ex-Jay
I have the same issues with my 94 XJ 4.0HO. I know its the ignition switch cause I can play with it and get everything working but as I'm driving down the road the radio, AC blower, turn signals will stop working. I've bought a new switch from autozone, removed the lower dash panel but cannot find this thing. Does anyone know the exact location of this switch for my year XJ? Also has anyone actually replaced one, and if so how did it go?
I saw a wire harness on the left side of the column about halfway down the column but the wire terminals/plug is not the same as the switch, and that's right below the bright switch.
I saw some wires leading up the column on the top side of the column but couldn't see if that's where the ignition switch was and if it is on the top of column mid way then I don't see how I can replace that without removing the whole column.
So like I said .... does anyone know exactly where this thing is located and how much of a pain is it to replace?
Thanks
Ex-Jay is offline
a/c, turn signals, wipers and more! Eman XJ Cherokee Technical Forum 4 08-18-2009 06:21 PM
No turn signals, wipers, or heat?? dge61785 XJ Cherokee Technical Forum 2 03-09-2008 08:13 AM
Turn signals, wipers and heater doesn't work. Jack Aubrey XJ Cherokee Technical Forum 8 06-19-2006 02:33 PM
Lost A/C, Radio, Turn signals Help LLERVERO XJ Cherokee Technical Forum 9 05-04-2004 09:29 PM
Radio, wipers, air, signals not working Greg B. XJ Cherokee Technical Forum 3 06-28-2002 11:46 AM
