no start, no bu5 - JeepForum.com
post #1 of 13 Old 06-25-2007, 11:44 AM Thread Starter
IAmJeff
no start, no bu5
I am new to the forums. i did a search and didnt turn up anything, so here goes. MY father in law has a '01 cherokee with the inline 6. the other day it wouldnt start, been running fin up until then. looked into it a little bit and noticed that it wasnt getting any fuel at the fuel rail. so we checked relays and fuses and everything was good. so we decided to replace the fuel pump. $120 later the jeep still isnt running, no fuel pressure. He told me that he had an error on his dash that read no bu5 before we did all this. also, the gas guage is at empty, but there was definitely gas in there. any help is greatly appreciated
IAmJeff is offline
post #2 of 13 Old 06-25-2007, 12:03 PM
mpwal099
mpwal099's Avatar
1997 XJ Cherokee
The "no bus" on the cluster is generally a loose connection in your dash. It is easy to pull the dash apart, pull out the cluster, clean the connections and put a little dielectric grease on it and put it back together. Might want to try that before tackiling anything else. It is the cheapest option.
When I die and go to heaven I hope the first thing God says to me is "The bar is right this way."
mpwal099 is offline
post #3 of 13 Old 06-25-2007, 12:55 PM Thread Starter
IAmJeff
that doesnt answer the no start problem tho does it? is this related?
IAmJeff is offline
post #4 of 13 Old 06-25-2007, 01:01 PM
mpwal099
mpwal099's Avatar
1997 XJ Cherokee
no it doesn't, but who knows it might just start after fixing that.
mpwal099 is offline
post #5 of 13 Old 06-25-2007, 06:34 PM
x99j
if i remember a crank position sensor has been known to cause a no bus once in a while along with your no power to fuel pump problem. some body with more knowledge please chime in. mike
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #6 of 13 Old 06-25-2007, 10:19 PM
dano.75
No Start
I am a mechanic and I came across this same error message on a Dodge van. Unfortunatly the problem is you computer and most likely will need to be replaced. Cost should be approx. $700
dano.75 is offline
post #7 of 13 Old 06-25-2007, 10:58 PM
gunner87
It was the CPS on my son's 01 XJ. He had the no bus code and would not run.
May be the same with yours.
Best
2006 Wrangler Unlimited
42rle tranny
gunner87 is offline
post #8 of 13 Old 06-26-2007, 07:23 AM Thread Starter
IAmJeff
it sounds like that no bus error can be caused by several things. id really prefer to not buy a bunch more parts that i dont need. does the cps going bad cause the fuel pump to not work?
IAmJeff is offline
post #9 of 13 Old 06-26-2007, 10:59 AM
x99j
the way i understand it when the pcm fires up it checks the cps. it the cps checks out good it the turns on the asd relay which in turn, turns the fuel pump and injectors on. something in that whole chain triggers the no bus. most no buses are due to a bad cluster connection. but not all no buses are are a bad cluster connection. i have heard of 4 no buses where the vehicle won't start and the cps fixed it. this is by no means gospel, just what i have experienced through friends. hopefully some more people will speak up about what they know! mike
x99j is offline
post #10 of 13 Old 07-11-2007, 02:02 PM Thread Starter
IAmJeff
we changed the CPS, problem solved. thanks a lot for all of your input
IAmJeff is offline
post #11 of 13 Old 07-11-2007, 03:43 PM
x99j
glad to here you got off cheap! how many miles are on you o1? just like to know so i can replace my cps when i am getting in the range of your mileage! mike
x99j is offline
post #12 of 13 Old 01-14-2008, 04:52 AM
spanish_lad
1993 XJ Cherokee
so a bad cps would shut down the fuel?
i have fuel at the rail but still no start does that mean that my problem is NOT the cps?
spanish_lad is offline
post #13 of 13 Old 01-14-2008, 07:04 AM
x99j
if you have spark it is not the cps!
some time a bad cps will cause the asd to shut down (no fuel) but not always!
start with the basics and check for spark!
x99j is offline
electric start prob. jeep wont start blackl4life XJ Cherokee Technical Forum 1 08-21-2009 09:56 AM
interesting hard start/no start/dead battery problem TXjeep97 XJ Cherokee Technical Forum 4 02-18-2008 09:18 PM
Hard start, every day its taking more and more cranking to start. Xride XJ Cherokee Technical Forum 8 11-27-2006 09:20 AM
Eh.. start? no start? roll the dice? jiggle the cable? UnderDog! XJ Cherokee Technical Forum 6 05-25-2006 10:14 AM
long cranking until start, then quick start mjahrens XJ Cherokee Technical Forum 14 08-11-2005 03:17 AM
