-   -   No start issue troubleshooting help. (http://www.jeepforum.com/forum/f11/no-start-issue-troubleshooting-help-1567489/)
rosco219 08-26-2013 07:00 PM
2000 Jeep XJ 4.0 2wd
245k
Problem: no start, no crank.
Symptoms: 4 days ago the jeep started by a slow moving starter as if the battery was dieing... Slow whinding up. I hear a suttle click under the glove box when turning key all the way..
What i have done:
1)replaced positive and negetive battery wires/terminals.
2)replaced with a Used starter off an 03 Grand cherokee (the solenoid wire connecter was different, so I spliced my old wire to the new starter) yes the starter tested good at pep boys.
3)checked all fuses in kick panel and under the hood. There all good...no burns or broken peices inside.
????? Possible relay? Ignition? I have had a tumbler issue in the ignition and have had to hit it a frw times with a hammer to knock it loose... All lights, radio, horn etc all work. I do get a beeping sound when the ignition key is on as well..
Also have jumped the solenoid wire to the positive terminal on the starter and the starter whinded up...the key was not on...
4)new battery , also have tryed jumping it with the new battery.
Holder350 08-26-2013 07:59 PM
Natural safety switch. Try starting in neutral.
There are ways to bypass the switch for testing purposes. The switch is repairable by cleaning and regreaseing.
Sent from my phone
rosco219 08-26-2013 08:17 PM
I tryed that already... Same thing
rosco219 08-26-2013 08:18 PM
If not clean could this still be the NSS. OR would it start in neutral either way?
Holder350 08-26-2013 08:31 PM
Could still be the NSS, you can pull the connector up in the engine compartment and cross a couple terminals to see if the switch is the issue.
Sent from my phone
Holder350 08-26-2013 08:37 PM
1 Attachment(s)
Unplug the switch and run a jumper from terminal B to C.
Make sure you add the jumper on the harness side of the connection and not the switch side, harness side should have the female terminals that you could stick a paperclip into.
If it starts like this your NSS is bad.
Attachment 661716
Sent from my phone
rosco219 08-26-2013 08:52 PM
So basically run a wire/ paper clip from b to c on the female side and keep it unplugged and try to start?
Where is this switch at ?
If its not this what else could it be
jeepster383 08-26-2013 10:47 PM
Check if you have voltage at the small wire at the starter. when the key is turned to start. Have a buddy help.
Holder350 08-27-2013 12:18 AM
You pretty much got it.
The switch is located on the transmission, and the connector should be on the firewall fairly close to the dipstick.
If this is not your issue, it could be a bad ignition switch, or even a broken wire somewhere.
Sent from my phone
rosco219 08-27-2013 04:46 PM
Which one is it? I see a grey plug and a black one near the dipstick...
rosco219 08-27-2013 04:58 PM
Attachment 661716
Sent from my phone
Is this the correct version for a 2000 though?..
rosco219 08-27-2013 06:03 PM
Ok so I jumped B and C with a wire and still nothing.... Im ****ing lost with this ****
rosco219 08-27-2013 07:11 PM
Just did it with a paper clip too
rosco219 08-27-2013 07:12 PM
Im getting a click some where in the passenger floor area....
rosco219 08-27-2013 07:41 PM
ahhh yes. It was the ignition lock cyclinder .. it wasnt pushing in far enough to engage I guess. I pressed in on the key fairly hard and felt a slight push and she turned over!!! Thank you for the help. So I guess I need a new ignition ? or did I really screw something up with all the banging around when the key was stuck.
The time now is 03:56 PM.
