No Start Checklist - JeepForum.com
post #1 of 3 Old 12-12-2012, 05:23 PM Thread Starter
OnTheFence
No Start Checklist
No Start Checklist
NOT CRANKING
  1. Check battery voltage (12V)
  2. Clean/tighten battery terminals. (Loose and/or corroded?)
  3. Check Gear Selector (Make sure you're in Park)
  4. Neutral Safety Switch (Try to start in Neutral, not Park)
  5. Is starter getting power? (With the key in the ON position, check for approximately full battery voltage at the starter.)
  6. Starter (Hit with hammer)
  7. Starter (Jump with screwdriver. Connect 2 highest bolts. 1 small. 1 big)
  8. Starter Motor Fuse #19 (Kick panel: Fuse #19 (10A red))
  9. Starter Motor Fuse #10 (Engine Bay Fuse Box (PDC). Fuse #10. See diagrams)
  10. Starter Motor Relay (Engine Bay Fuse Box (PDC). “Cube” relay at end of fusebox)
  11. Ignition Switch (Turn on the blower motor fan on for your heater with your key in the 'run' position. Turn the key to the 'start' position... the fan should turn off as it trys to crank over, indicating a good ignition switch.)
CRANKS, BUT NO START
  1. Is gas tank empty?
  2. Fuel pressure. 48psi (+/- 5psi). Listen for Fuel Pump?
  3. Fuel pump relay (Engine Bay Fuse Box (PDC). Fuse #22. See diagrams)
  4. Ignition fuse (Kick panel: Fuse #11 (20A))
  5. Check for spark.
  6. Bad spark plugs?
  7. Bad Distributor, Cap, Wires?
  8. Crank Position Sensor (CPS)
  9. Bad coil pack?
  10. Bad ECU?
Kick Panel Fusebox
Misc reading:
http://www.cherokeeforum.com/f2/non-...writeup-71401/
http://www.cherokeeforum.com/f2/long...8/#post2182489
http://www.jeepforum.com/forum/f11/p...l#post10006643
http://www.jeepforum.com/forum/f11/p...9/#post7683626
http://www.naxja.org/forum/showthread.php?t=101119
http://www.jeepforum.com/forum/f11/b.../#post14517948
OnTheFence is offline
post #2 of 3 Old 12-12-2012, 09:22 PM
KG8893
add to the cranks but no start, for the 97+ xj if the battery was recently disconnected to give some gas and hold it. The ECM needs to regain it's memory of the idle speeds if it has been completely discharged.
I'm not saying we should kill stupid people... Just get rid of all the warning labels...
If you find my comments to "infer" something, they don't. Go to hell.
Built Not Bought #666
KG8893 is offline
post #3 of 3 Old 12-13-2012, 09:35 AM
AmbuGrl
AmbuGrl's Avatar
Always check your ground...
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
