No Spark, No Fuel 98 Cheeroke Sport 4.0L - JeepForum.com
post #1 of 4 Old 03-02-2011, 05:25 PM Thread Starter
BeepTheJeep98
I've got a 98 Jeep Cherokee Sport 4.0L. I think I left one of the interior lights on and it killed the battery. I recharged the battery but now it just cranks but I have no spark at the coil and the fuel pump is not energized. After reading up on similar problems I replaced the Crankshaft Position Sensor. Nothing changed from the original condition. Fuses are all good. The gas and battery gauges do not move when the key is turned.
Thanks in advance for any help.
BeepTheJeep98 is offline
post #2 of 4 Old 03-02-2011, 05:31 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
You still have classic symptoms of a problem with the crank sensor circuit. The gas and battery gauges are big clues there, as there is often problems with those gauges with a bad crank sensor.
Where did you purchase your sensor from? There have been numerous threads of bad aftermarket sensors right out of the box. The crank sensor is one that I always buy directly from Jeep.
Otherwise, you need to make sure that the crank sensor connectors are good, as well as wiring. Get a can of electrical contact cleaner, spray both the crank sensor connectors thoroughly (there is also one near the #6 injector/firewall), add a small dab of dielectric grease and reconnect.
ASD (autoshutdown) circuit is a remote possibility, but I think you have an engine management sensor problem and the crank sensor is still high on the list.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 4 Old 03-11-2011, 10:45 AM Thread Starter
BeepTheJeep98
I ended up taking it to the Jeep Dealership. They are telling me that the PCN is bad and needs to be replaced. They quoted my $500 just for the part. They warned me that getting a used PCN would most likely not work because the PCN's are VIN specific. I don't know if that's a real thing or not. Any ideas on what I should do?
post #4 of 4 Old 03-11-2011, 02:17 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
See this thread. -> http://www.jeepforum.com/forum/f11/d...e-pcn-1180335/
CJ7-Tim is offline
01 Cheeroke Diagnosing Codes blindlightguy XJ Cherokee Technical Forum 9 08-14-2010 01:29 AM
'94 Cheeroke won't crank dlauq XJ Cherokee Technical Forum 14 05-24-2010 03:54 PM
jeep cheeroke front end popping morg XJ Cherokee Technical Forum 12 09-02-2009 05:49 AM
No Fuel at rail but had spark, replaced pump, has gas, no spark. wtf? Element96x XJ Cherokee Technical Forum 2 03-28-2009 05:11 AM
97 Cherokee Sport 4L No Spark/Fuel dolfan87 XJ Cherokee Technical Forum 7 05-18-2007 09:04 PM
