No Spark issue still cranks...tunnel vision and stumped. - JeepForum.com
post #1 of 6 Old 09-03-2011, 01:20 PM Thread Starter
Hahnz
So here it is..1996 xj 4.0 with 240,000 and was running strong until recently.
Had it running, threw it in reverse and it died out with no stumbling just quit.
Jumped to conclusion and replaced cps and no luck starting again. Found out it was fuel pump and replaced and now its getting gas again but now there is no spark. Checked coil and that checks out good on the ohm meter. Pulled distributor cap and rotor is spinning as well. Swapped asd relay and still no luck. Next thing to do is light test all the fuses and tomorrow I'm going to try and throw a scan tool on it.
When I bought my new cps it was the right sensor but the wrong plug. So I spliced the plug with the correct one and installed with still no spark and I put the old one in just for kicks and still the same symptoms.
Any insight would be greatly appreciated!
Hahnz is offline
post #2 of 6 Old 09-03-2011, 01:23 PM
spdcat01TJ
I'm having the exact same issue! I've replaced the CPS, and swapped the ASD relay as well. No fire coming from the coil. Sporadic voltage to the coil. I'm gonna try replacing the coil. (I have a spare)
The distributor shaft has a lot of play in it, and I'm wondering if the Camshaft position sensor in the distributor may be bad and causing the PCM to not send a signal to the ASD to power the coil.
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
NRA Member
'01 TJ Sahara, 3" BB front, 2.25" BB rear, 1.25 JKS BL, 1" MML, Skyjacker Hydro shocks,33/12.50x15 BFG TA/KO All Terrains homemade disco's, Hi-Lift, CB, GPS
spdcat01TJ is offline
post #3 of 6 Old 09-03-2011, 01:30 PM Thread Starter
Hahnz
I'm just boggled that the fuel pump goes out and all of a sudden I have a spark issue...what are the odds???
Hahnz is offline
post #4 of 6 Old 08-04-2012, 12:19 PM
87manche17
1987 MJ Comanche
Ive heard your ignition coil can get a bad ground, I don't exactly know how to fix it though.
87manche17 is offline
post #5 of 6 Old 08-04-2012, 12:41 PM
buildin1XJ
Do your reverse lights come on when you shift it into reverse? have you tried to start it in neutral,or jiggled your shifter around to se if it will start.If any of this is occurring you may neeed to either clean or replace your Neutral Safety switch NSS
buildin1XJ is offline
post #6 of 6 Old 08-05-2012, 10:19 AM
87manche17
1987 MJ Comanche
Yes, my NSS is fine I believe its my ignition control module, because I have power going to the module but none coming from the coil.
no spark
97 xj 4.0 Cranks No spark new cps nd4spd4axj XJ Cherokee Technical Forum 30 06-03-2014 10:33 AM
cranks, but no spark dirtdad XJ Cherokee Technical Forum 2 07-29-2011 04:55 AM
'98 still no spark..my mechanic is even stumped! seank XJ Cherokee Technical Forum 18 05-02-2011 07:52 PM
No spark...and I am stumped BCC XJ Cherokee Technical Forum 10 09-29-2010 07:48 PM
4.0 cranks but no spark ZeroLag XJ Cherokee Technical Forum 6 08-24-2009 12:18 PM
