no spark,1990 cherokee sport 4.0l - JeepForum.com
post #1 of 4 Old 04-25-2010, 10:35 PM Thread Starter
mike13
1990 XJ Cherokee
Please help!ran fine the day before the problem but the next morning wouldn't start.just cranks over.I have already changed the cap,rotor,coil,icm,and cps.Could it be the ecm?Thanks in advance
mike13 is offline
post #2 of 4 Old 04-25-2010, 11:36 PM
HenryKrinkle
1988 XJ Cherokee
Well, you should probably check all your grounds and connections. You've checked for spark and still nothing? If so, the neutral safety switch has been known to cause no-start situations. Try starting it in park and in neutral. Not sure if it's the nss or the cps that could start in N vs P.
Could it be a fuel issue? Maybe your pump is shot, something along those lines. Look up fuel pressure tests in your manual or online.
Or a preliminary test: I think you just pull the 4 bolts off the rail, wiggle the injectors loose without turning them too much. Then you would find something to catch the fuel spray with (*Fire extinguisher handy) and turn it over. Pretty sure all should spray at first.
If that's good: do your pressure test.
If that's bad: probably fuel pump.
Whenever you remove the injectors it's a good idea to replace the o-rings. Leaky fuel obviously a major fire hazard. O-ring kits are under 15 bucks- 2 rings per injector and one or more for the pressure regulator which you probably wouldn't need to mess with. My manual says to use the black/brown o-rings on specific ends of the injectors, but my kit came with all brown o-rings which is just fine. Use Vaseline on the rings to seat them. Helps you install without any damage and will get eaten away by fuel with no adverse effects.
HenryKrinkle is offline
post #3 of 4 Old 04-26-2010, 04:49 PM
aviat0r
Hi, to add a little info, this jeep is a manual transmission and there is fuel pressure. He also just tried a different ECM with no luck. Seems to be getting fuel just not igniting it.
Any other ideas?
aviat0r is offline
post #4 of 4 Old 04-27-2010, 05:30 PM Thread Starter
mike13
1990 XJ Cherokee
i had it towed to a shop and they discovered that when i replaced the cap i was one off on the wires.runs fine now but i feel like a *******.I asked them about the spark problem and they said it was probably the crank sensor.I replaced the cap before the crank sensor so that is why it didn't start.Thanks for your help!
mike13 is offline
1990 Cherokee, no spark Leobram XJ Cherokee Technical Forum 14 08-03-2012 12:29 PM
1990 Cherokee no spark Leobram XJ Cherokee Technical Forum 1 08-25-2009 12:24 AM
1990 Jeep Cherokee Sport 2-door harrydunn XJ Cherokee Technical Forum 1 10-25-2007 08:54 AM
1990 Cherokee Sport ... got some questions...:) sweeper2 XJ Cherokee Technical Forum 11 09-12-2006 04:49 PM
1990 Cherokee Sport high rpms? ABZACK XJ Cherokee Technical Forum 4 07-25-2006 10:54 AM
