No Second Speed on Heater Fan - JeepForum.com
post #1 of 4 Old 03-12-2011, 03:15 PM Thread Starter
BZman
Hi Everyone,
I just joined the forum and hope I can get some help.
I've got a 99 cherokee 4x4 4 liter completely stock. The problem is that I lost the second speed on my heater fan. That seems to be the only speed that is gone. When it is on the first speed I can't hear it running, but I can feel a little heat comming out and 3 and 4 work fine.
So my question is, do you think it is the resistor or the fan switch that is bad.
Thanks for your help.
BZman is offline
post #2 of 4 Old 03-12-2011, 03:39 PM
mortalenema
mortalenema's Avatar
I vote for the resistor being bad?
Did you read this?
http://www.jeepforum.com/forum/f11/f...gh-wtf-656659/
KICK COVER
REMOVAL
(1) Disconnect and isolate the battery negative
cable.
(2) Loosen the two screws that secure the upper
half of the kick cover to the heater-A/C housing
under the passenger side end of the instrument panel
(Fig. 52).
(3) Remove the two screws that secure the lower
half of the kick cover to the heater-A/C housing.
(4) Pull the kick cover down towards the floor
panel to disengage the slotted upper mounting tabs
from under the two loosened heater-A/C housing
screws.
(5) Remove the kick cover from the heater-A/C
housing.
BLOWER MOTOR RESISTOR
cable.
(2) Remove the kick cover from the heater-A/C
housing. See Kick Cover in this group for the procedures.
(3) Pull out the lock on the blower motor resistor
wire harness connector to unlock the connector latch
(Fig. 18).
(4) Depress the latch on the blower motor resistor
wire harness connector and unplug the connector
from the resistor.
(5) Remove the two screws that secure the resistor
(6) Remove the resistor from the heater-A/C housing.
(7) Reverse the removal procedures to install.
Tighten the mounting screws to 2.2 Nm (20 in lbs.).
mortalenema is offline
post #3 of 4 Old 03-12-2011, 04:35 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
When the thermal fuse on the resistor pack goes you normally only get "high". I might suspect the dash controls.
Michael
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #4 of 4 Old 03-12-2011, 04:37 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Originally Posted by mecompco View Post
When the thermal fuse on the resistor pack goes you normally only get "high". I might suspect the dash controls. Michael
I agree that the heater switch in the dash is the most suspect, if speeds 3-4 work.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
99 cherokee heater core replacement tips / low heater output 01xjltd XJ Cherokee Technical Forum 14 06-30-2013 09:53 PM
need help with heater hose routing around heater control valve jerry4570 XJ Cherokee Technical Forum 2 10-11-2009 11:35 AM
Heater blower 1-2-3 speed died all at once NorthernStang XJ Cherokee Technical Forum 3 08-17-2009 03:13 PM
swap 4 speed with a 5 speed.dont know if they make one the87XJkid XJ Cherokee Technical Forum 8 08-11-2009 06:56 AM
Heater fan only works on high speed peterp XJ Cherokee Technical Forum 2 09-02-2008 05:44 AM
