no problem like someone elses problem - JeepForum.com
post #1 of 3 Old 05-11-2010, 08:37 PM Thread Starter
too_low
I just bought a 91 jeep Cherokee Laredo from a guy who tried to put an engine in it. from what I gather the old engine overheated and blew up so he bought a junkyard engine out of a 1995 jeep?????? He said he used the wiring harness and ecu from the 91. everything works correctly (fuel starter lights) except for the ignition and the tach, he put a new 91 distributor on it and it only has spark on #3 and 4 cylinders, i put a distributor off of a 94 jeep grand Cherokee in it and it only has spark on #2 and 5 cylinders now. The combination of wrong spark timing and the tach not working points to the crank position sensor, however it's new. Is there a possibility that the flex plate from a 95 is different from a 91 and could that cause the cps to read the position wrong?? Thanks
too_low is offline
post #2 of 3 Old 05-11-2010, 08:48 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would assume that you need a 91 flexplate, distributor, and CPS to make it work correctly. I am unsure if the 91 and 95 are different but there were different ones for different years.
xjfever is offline
post #3 of 3 Old 05-11-2010, 09:08 PM
cruiser54
1990 MJ Comanche
You can check parts application at rockauto.com.
cruiser54 is offline
cps , flex , intermittent , plate , spark
Unknown problem idle problem drunkenmonke XJ Cherokee Technical Forum 6 12-22-2007 11:56 AM
My problem with defrost/floor vent problem found ebk04 XJ Cherokee Technical Forum 2 07-17-2006 12:37 PM
Anyone elses NP-231 do this? XJ4oh XJ Cherokee Technical Forum 16 06-01-2006 12:42 PM
Problem starting in warm weather! Anyone has the same problem?? keon XJ Cherokee Technical Forum 6 04-14-2006 07:39 PM
my fan comes on all the time..anyone elses? GM JOE XJ Cherokee Technical Forum 19 12-03-2005 01:28 PM
