No Power Anywhere! - JeepForum.com
post #1 of 38 Old 10-19-2008, 08:57 PM Thread Starter
89SAFARIXJ
1989 XJ Cherokee
No Power Anywhere!
I have an 89 cherokee and i put in a new alternator last nite. hooked up the right cables in the right spots on the alter nator as it was pretty much self explanatory. threw a new belt on, tightened it up, and hoppe in to start it up and see how it was gonna do.
except i didnt have enough juice in the battery to start and it was 11:30pm, so i waited til today.
just rolled it out of the garage for a jump. popped the hood and the underhood light didnt come on. so i figured the battery drained itself over night. we hooked up the cables to my dads silverado then hooked em to my jeep. red on red. black on black. the way youre supposed to. (i guess i could have found a ground on my jeep...)
anyways i hopped in, turned the key, heard a click, and had no power. ANYWHERE.
no radio, lights windows.... ABSOLUTLEY NOTHING. and definatley not a running jeep.
ughhh. now what? this is my dd so im like WTF.
-Sean
89SAFARIXJ is offline
post #2 of 38 Old 10-19-2008, 09:05 PM
zipXJ
1989 XJ Cherokee
Other than the alternator replacement the same thing just happened to my 89. I pulled the battery and had it tested. It had a bad cell. Replaced it (free - gotta love warranties) and off I went. Hopefully it's your only issue.
Good luck!
zip >>
zipXJ is offline
post #3 of 38 Old 10-19-2008, 09:11 PM Thread Starter
89SAFARIXJ
1989 XJ Cherokee
thanks for the input man. well too bad i bought this cherokee and it already had a battery in it. i have no reciepts for the battery or anything. dont know where it was bought. the date that the battery was put in the jeep isnt even recognized on the battery. someone forgot to mark it.
post #4 of 38 Old 10-19-2008, 09:18 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
yeah batteries can die to the point of no return. which it sounds happened to you. might want to get it tested like suggested. or maybe just clean the terminals really well. mine used to randomly have no power like you are describing, due to a bad/dirty/loose battery cable
1990JEEPXJ is offline
post #5 of 38 Old 10-19-2008, 09:23 PM
footypaul
Dont have another battery out of another vehicle to try in it?
footypaul is offline
post #6 of 38 Old 10-19-2008, 09:26 PM Thread Starter
89SAFARIXJ
1989 XJ Cherokee
GENIUS!!!!!!
this is dumb tho because before i replaced the alternator everything worked fine. never had any battery troubles...
post #7 of 38 Old 10-19-2008, 09:30 PM
footypaul
Originally Posted by 89SAFARIXJ View Post
GENIUS!!!!!!
Sorry man, i wasn't trying to be a smart ###, but ive worked on vehicles before, and SWORE whatever I did to it had to be the problem after i was done, and it ended up being something completely different. You just gotta start simple, with stuff like are you sure the computer is plugged in, is there there gas in it, etc?
post #8 of 38 Old 10-19-2008, 09:30 PM Thread Starter
89SAFARIXJ
1989 XJ Cherokee
but wait. even if it had a bad cell. my dads silverado was hooked up to it. his battery is good. i should have still had power to my cherokee with his truck hooked up, even if i had a bad cell.
fuseable links?
post #9 of 38 Old 10-19-2008, 09:31 PM Thread Starter
89SAFARIXJ
1989 XJ Cherokee
yes.......
post #10 of 38 Old 10-19-2008, 09:32 PM Thread Starter
89SAFARIXJ
1989 XJ Cherokee
......but it just went click when i turned the key to start it. then i lost all power..... GRRR.
post #11 of 38 Old 10-19-2008, 09:33 PM
footypaul
That does sound like some kind of fuseable link or something. Does it do anything at all now, click or anything, or was it just one click and done?
post #12 of 38 Old 10-19-2008, 09:42 PM Thread Starter
89SAFARIXJ
1989 XJ Cherokee
i just went out to double check.
it makes no sound now. no click. nothing. silence.
post #13 of 38 Old 10-19-2008, 09:42 PM
boman40
boman
1995 FSJ Cherokee
Do you or your dad have a volt meter? see if you have 12 volts at the battery.
If battery voltage is low try charging the battery again, when batty is fully charge leave it set over night and check voltage again. If low, buy new battery.
When jumping a dead battery, sometimes you have to leave the cables hooked up awhile before trying to start the jeep. The cold outside it is the longer the wait.
boman40 is offline
post #14 of 38 Old 10-19-2008, 09:48 PM Thread Starter
89SAFARIXJ
1989 XJ Cherokee
how does this make any sense if when i turned the key, when the truck was hooked up to it, it went click????
can you explain?
post #15 of 38 Old 10-19-2008, 09:50 PM
footypaul
Did you leave the cables hooked up for a while? Did any of the underhood/interior lights come on when you hooked it up?
Driver Door no power lock and also no power mirrors asudds XJ Cherokee Technical Forum 2 01-27-2011 08:06 PM
Specific seat swap question: 97 ZJ Lmtd power leather into 96 XJ non-power... Thegonagle XJ Cherokee Technical Forum 3 12-24-2008 10:23 AM
No cigarette lighter power, no power locks kadetklapp XJ Cherokee Technical Forum 3 12-19-2008 12:44 PM
Power Windows and Power Locks problem... Josh_is1 XJ Cherokee Technical Forum 4 06-11-2005 05:45 PM
need help sending power to power seats and power lock babas151 XJ Cherokee Technical Forum 4 09-13-2004 09:31 AM
