No Lights ... High Beam Indicator On - JeepForum.com
post #1 of 2 Old 05-13-2013, 02:10 PM Thread Starter
KPBJeep
I have a 2000 Jeep Cherokee Sport with a 4.0 Engine. The front headlights went out and when you turn on the lights, the High Beam Indicator comes on.
Any Ideas????
KPBJeep is offline
post #2 of 2 Old 05-13-2013, 06:29 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Use your $8-16 Volts/Ohms Multi-Meter you purchased at the local hardware store, home improvement store, or WalMart type store to test for 12 volts and ground at the headlight plugs. Inspect the headlight relays and test for 12 volts. Test for 12 volts at the headlight switch. Consider that the headlight switch or the turn signal multi-function switch may have failed. Look for corroded/damaged/melted wires and wire plugs.
CJ7-Tim is offline
lights
