No idle... - JeepForum.com
post #1 of 3 Old 07-07-2005, 07:47 AM Thread Starter
Wulf711
Wulf711's Avatar
2017 JK Wrangler
Unhappy No idle...
I have an opportuinty to buy a cheap 2000 XJ SE that is pretty banged up. The problem with it that I am worried about is the fact that I cant get it to stay running at Idle. It will start and sounds good if I feather the gas but let the foot off the gas and it dies..... It has been a while since I have had to diagnose a problem like this so..... The ALternator is bad so the battery is dead and it has had some cooling issues due to a run in with a drill auger which crunched the front fairly bad.....
Any advice would be grately appreciated...
Please post or email me at ghorn@arcadis-us.com
Gabe
1997 XJ green, 5 sp, 2 door <<<DD/Project Vehicle>>>
1989 YJ Red, 5 sp which is in bad need of repair. I just need about 26 hours a day and it will be all good.
Part Donations? I need to get this beast Rally Ready!
Live in New York Play Everywhere
Parrothead Jeepers Union Member #15
Wulf711 is offline
post #2 of 3 Old 07-07-2005, 08:42 AM
XJH-007
XJH-007's Avatar
Yikes. Better be cheap.
Before you can really diagnose anything you need to get the charging system working. Since the fuel pump is electric and the idle speed controls are electric, having a bunk elec. system could lead you in the wrong direction to fixing it.
It could be as simple as a dirty throttle body, but you won't know till she's charging herself and holding a charge.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #3 of 3 Old 07-07-2005, 02:13 PM Thread Starter
Wulf711
Wulf711's Avatar
2017 JK Wrangler
correcto
I hooked it up to a truck that was putting out more Amps than my portable jumper and it held idle. I am thinking that I tackled that problem. Now I just need to get the front fix and all the mud off of the undercarraige, drivetrain, interior...... hell what do you expect for $500. I will have to do a build up website....
Gabe
Wulf711 is offline
Rough idle, stumble at idle. 98xjnick XJ Cherokee Technical Forum 2 03-23-2010 03:18 PM
no vac leaks - backfire, rough idle, fast idle, slow response alhefner XJ Cherokee Technical Forum 7 09-16-2009 12:58 AM
will the air idle control make a moter idle too fast? mhall101 XJ Cherokee Technical Forum 19 06-10-2009 09:10 AM
Idle...but no go..... atv_fanatic XJ Cherokee Technical Forum 5 05-19-2009 07:31 AM
Light knocking noise at idle (and slightly slow idle) Calpolyclimber XJ Cherokee Technical Forum 14 04-28-2004 04:37 PM
