Quantcast New toys installed pics - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > New toys installed pics
Old 09-08-2008, 09:19 PM   #1
the6nightmares
So after a years worth of sagging rear springs, I finally ordered the full RE 3.5" The removal of the old pair was quite the pain, had to buy an angle grinder and cut through the leaf, then through the bushing. PITA, and what a mess. the end rusult is nice though. heres a few pics of the new leaf packs and some other goodies, including the new mud terrains and wheels
Next up we've got the JKS sway bar discos, what an easy addition that was, finished in about 45 minutes.
New front diff skid, inside that diff is the Aussie Locker, not a bad install.
Cleaned up the underside, painted the axles and whatnot
Also put new axle seals and bearings in the rear
How she's sitting now
Baltimore County Jeep Club
"A squid eating dough in a polyethylene bag is fast and bulbous. Got me?"
the6nightmares is offline   Reply With Quote
Old 09-08-2008, 09:21 PM   #2
the6nightmares
Cleaned up the interior
Old 09-08-2008, 09:25 PM   #3
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
Looking good, now go get it dirty
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 09-08-2008, 09:36 PM   #4
the6nightmares
ridin dirty
Here is what we did this weekend
http://www.jeepforum.com/forum/f177/maiden-voyage-new-beast-604121-post5678279/?posted=1#post5678279
Old 09-08-2008, 10:04 PM   #5
taylor4857
sweeeeeeeeeeeeeet!!!!!!!!!!
taylor4857 is offline   Reply With Quote
Old 09-08-2008, 10:33 PM   #6
tdogg55555
Do you have a locker in the 8.25? Or just the aussie in the front?
96 Country...Weekend warrior
tdogg55555 is offline   Reply With Quote
Old 09-08-2008, 10:41 PM   #7
XJRookie
1994 XJ Cherokee
looks good!!!
I have a stupid question though.....why are you discos laid back like that? I'm trying to figure out that picture and something just doesn't look right to me......here is a picture of mine.....
....what am I missing in your pic???!!!
1994 XJ Sport
4" ProComp Lift with full leafs
Rock Krawler Wheels/X-treme Mud Terrain 31x10.50
Banks Torque Tube w/Dynomax Super Turbo Cat-Back
K&N Fuel Injection Performance Kit
XJRookie is offline   Reply With Quote
Old 09-08-2008, 10:57 PM   #8
bmyohn
Youngin'
bmyohn's Avatar
his are disconnected and stored on the pin attached to the bash plate. in your pic your sway bar is connected, in his its not
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 09-08-2008, 11:01 PM   #9
Mr_Random
1986 XJ Cherokee
looks like he made a mounting point on the front skid where they can be kept when unhooked?
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
http://www.jeepforum.com/forum/f22/86-xj-w-mpi-budget-re-build-757079/
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline   Reply With Quote
Old 09-08-2008, 11:05 PM   #10
XJRookie
1994 XJ Cherokee
That would make sense! I see it now that you say that!
1994 XJ Sport
Old 09-09-2008, 01:04 AM   #11
gweezo698
Originally Posted by XJRookie View Post
looks good!!!
Just FYI....I think your disco is mounted wrong
-01 XJ 4.0 auto 31s ARBs and armored
-96 XJ stock 4.0 5spd SOLD
-94 XJ 4.0 5spd 3" 33s(beater/parts)SOLD
-96 XJ 3" Rusty's 4:56s f/ARB r/Detroit 35s SOLD
-84 CJ-7 4.5" 35s locked SOLD
-97 TJ Sahara 3.5" 34s locked SOLD
gweezo698 is offline   Reply With Quote
Old 09-09-2008, 06:55 AM   #12
FitchVA
Jeeper 4 Life
FitchVA's Avatar
very clean and sharp rig mang
'98 xj sport (trail toy) | specs
'98 xj classic (dd'er) | specs
'89 mj tinker toy | specs
My XJ Page | My Gallery
FitchVA is offline   Reply With Quote
Old 09-09-2008, 10:33 AM   #13
Giviner
looks good!!!
His are disconnected and hooked onto a mounting bolt on the frame that keeps the links up and out of the way while wheeling. Yours are connected. that is the main difference.
Also, his are mounted to the swaybar correctly, yours arent.
The top of the link mount is supposed to be on top of the swaybar and bolted down through it. Yours is mounted to the bottom and bolted up through the link. You might not have any issues if you used big washers and grade 8 hardware but I would probably mount them the proper way since it is much stronger.
2003 TJ Sahara
1988 XJ
www.jeepsofmcmurray.ca
Giviner is offline   Reply With Quote
Old 09-09-2008, 04:57 PM   #14
biggerbrowndog
nice xj!
where did you put the amps?
biggerbrowndog is offline   Reply With Quote
Old 09-09-2008, 05:30 PM   #15
black2door
HAHA
black2door's Avatar
1997 XJ Cherokee
Looking good man!
-Andrew
Another Chero in progress
black2door is offline   Reply With Quote
Glock Forum
