New tech article: Removing stock swaybar links - JeepForum.com
post #1 of 14 Old 09-05-2004, 11:08 PM Thread Starter
GottaBeJeep
I know a lot of you guys have already removed your swaybar links, but for the new guys that don't know that the torx bolt is pressed in, not threaded, this will be very helpful...I hope.
http://www.rocklizardfabrications.co...r_endlinks.htm
...Off Road Armor that's "Tough as Scales"
GottaBeJeep is offline
post #2 of 14 Old 09-05-2004, 11:18 PM
4ever9er
4ever9er's Avatar
http://www.rocklizardfabrications.co...sco_mounts.htm
Wow, you went through alot of work to remove that bolt! Yours must have been rusted in pretty well.
I took mine out yesterday and it took me maybe 15 minutes.
Just took the nut off and used a chisel aimed between the steel plate and the head of the torx bolt... about 6-8 good whacks, and the bolt came out.
(2000 Cherokee Sport)
Quick disconnect pins I used were 1/2" X 2" from Lowes.
Good Luck! ; )
4ever9er is offline
post #3 of 14 Old 09-05-2004, 11:19 PM
Alexia
Alexia's Avatar
Wow... could have used this a few weeks ago. I have a really bent out of shape axle bracket now...
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #4 of 14 Old 09-05-2004, 11:26 PM Thread Starter
GottaBeJeep
Alexia: Sorry, I guess I should have done this writeup as soon as I actually finished that project (about 3 weeks ago). Don't worry, I'll kick myself for you.
4ever9er: It may seem like a lot of work, but many times the torx bolt is stuck in there pretty good. I have removed many of those bolts, and it is just easier to do it this way every time. The article is to help a lot of the new guys that spend a lot of time trying to turn that bolt out because they don't know it is pressed in, and end up on these forums asking why they can't get the bolt out. Air chisel works, but mine will get a few wacks at the end of the bolt, then I'll miss. I don't like to waste time missing that dang bolt. I want to get it out as fast and easy as possible. Time is money.
post #5 of 14 Old 09-06-2004, 04:01 PM
ColoradoXJ13
I just heated with an acetylene torch, got it nice and red, then tool an air wrench with a torx head, spun it, and knocked it out with a hammer, 5 minutes max
ColoradoXJ13 is offline
post #6 of 14 Old 09-06-2004, 08:40 PM
DMacabre
kinda makes me feel stupid for cutting them off and then drilling them out.... hey, whatever works right?
88 MJ: some assembly required
98 XJ 2dr: little lift, lotta skidplate
DMacabre is offline
post #7 of 14 Old 09-06-2004, 09:08 PM
chow
ya I wished you hasd posted it sooner, I drilled my out, well still working on that one. I drilled through it, but parts of it are still there.
Mitsu Diamante~92
Chevy 2500HD Diesel~06
Jeep Cherokee~96
Rusty's Intake & TB Spacer, Banks Header, CSF 3-Core Radiator & MagnaFlow 2.5 SS Cat-Back Exhaust....
R.E. 6200 5" w/Bilstein 5150, JKS UCA & LCA, HighAngle CV Drive shaft, 1987 Dana 44 & R.E. SYE....
Custom 4X4 Fabrication Diff Gards D30 & D44, JKS SuperNerf Rails, DPG OFFROAD T-Case, Custom Roll Cage, Front & Rear Bumper by Ryan's Roll Cage.....
AR 797 15X8 W/FireStone Destination MT 31" , Warn 9.5 XP Winch ~
chow is offline
post #8 of 14 Old 09-07-2004, 02:22 PM
cyberbackpacker
cyberbackpacker's Avatar
Thanks for a great article. Another example of what makes this such a great article. Passing on the knowledge to help others! I appreciate it!
-Kevin
cyberbackpacker
cyberbackpacker is offline
post #9 of 14 Old 09-07-2004, 03:12 PM
gecko321
i took mine out with a pair of vice-grips....grabbed the head and twisted a little and out it came....
mike
90' Cheroke 4.0l AW4 | 5" lift | Custom Long Arms
34x10.50 LTBs on 15x7 Junkyard Wheels
Custom 2x3 Rock Rails | Custom Roof Rack | Custom Tube Doors
4Runner Roll bar | Welded D30 & 8.8 | MM PE8000 Winch
gecko321 is offline
post #10 of 14 Old 09-29-2009, 01:21 PM
TJ_Jeeper_97
my torx bolt came right out, its the top bolt im having trouble with. anyone?
97 TJ---31s, Custom Snorkel, 2'' lift, 4' firestik, hood mounted lightbar, body damage...
Ronin Wheelers of New England
TJ_Jeeper_97 is offline
post #11 of 14 Old 09-29-2009, 02:03 PM
TJ_Jeeper_97
nevermind lol 4x4 explorer used a tie rod puller. JF is awesome!
post #12 of 14 Old 09-30-2009, 05:33 AM
jeep12827
1987 XJ Cherokee
does it hurt to just use the torx head bolt and still bolt your discoes to that? thats what i did with my rough country 4 -6 inch quick discos
jeep12827 is offline
post #13 of 14 Old 09-30-2009, 07:13 AM
Kettles
If you bolted your rough country discos to the factory bolt, then that defeats the whole point of discos. How do you disconnect the RC ones, I thought they were a solid link, and they only used a quick disco lower bolt.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #14 of 14 Old 10-01-2009, 04:38 PM
jeep12827
1987 XJ Cherokee
no they have the bushings on top and bottom of where they bolt up like the old stock link but the center tube part has pins that go through and hold it when u pull them out then the tube comes apart
longer stock type swaybar links?? Tomsjeepnj XJ Cherokee Technical Forum 4 01-31-2008 09:36 PM
problem removing stock sway bar links atfrith XJ Cherokee Technical Forum 9 01-14-2005 07:23 PM
New tech article, 2wd guys pay attn XJ Fanatic XJ Cherokee Technical Forum 55 12-13-2004 02:00 PM
New tech article for the 98+ guys XJ Fanatic XJ Cherokee Technical Forum 2 12-01-2004 05:29 PM
New tech article: Adjusting your bumpstops GottaBeJeep XJ Cherokee Technical Forum 1 07-18-2004 08:03 PM
