Quantcast New rear leaf bushings.... how can I get them in the leaf? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > New rear leaf bushings.... how can I get them in the leaf?
Old 12-05-2006, 08:43 PM   #1
Xride
I bought some new bushings for new leafs I bought, but how do I get them in?
The new bushings seem to be in a metal sleeve, and it doesnt fit into the leaf very well, I only have a 5lb hammer, and with it and a block of wood I cant even get it started.
Do I just need a bigger hammer?
1999 XJ, black, 4x4, NP231 Command Track, 8.25 rear.
3" Old Man EMU, 30" x 9.5" x 15" General Grabber AT2
Xride is offline   Reply With Quote
Old 12-05-2006, 08:55 PM   #2
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
Could try lightly warming the spring ends with a propane torch to expand the metal. I had a similar iinstall like this and I used lots of penatrateing oil inside and on the bushing and then a lot of swinging.
If you have a fab shop intown they can probably press them in for you and not risk damaging them in doing so.
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
Jeep Pic's
coppertop71 is offline   Reply With Quote
Old 12-05-2006, 09:01 PM   #3
Xride
The fab shop wants 65 bucks to press them in, even after they admit its only 5 minutes work.
Several other places wouldnt press them in unless they did the install. Kinda gay.
I wonder if I can jack them in against the motorhome frame or something? its gotta weight enough (46' coach)
Old 12-05-2006, 10:37 PM   #4
Cerealdaemon
1988 FSJ Wagoneer
Thats not a bad idea, put them between something really solid and then use a bottle jack to press them in. Its the same basic idea for a tool that shops have, except that with those machines, you press down and not up. Give it a shot, but wear some eye protection
"stand over and deliver, or the Devil he may take ya!"
Cerealdaemon is offline   Reply With Quote
Glock Forum
