Quantcast New Owner - Front Plate Question & Tire Sizing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > New Owner - Front Plate Question & Tire Sizing
Old 11-20-2009, 08:40 PM   #1
UNHCLL
Junior Member
Hi Group,
I am a new owner of a '99 Classic.
I bought it to serve as a daily commuter and winter ski trip machine.
The Jeep came without any provision to mount a front license plate to the bumper, something which is mandated here in New Hampshire.
Can someone tell me if one of the following links is the correct part to mount a plate using the OEM method? I looked under the bumper, and there are 2 white plastic screw recepticles to attach a plate mount. However, when searching for a plate mount, the options that come up for a '99 don't look to use this method of mounting?
Alternatively, if someone here has an OEM front mount from their '99 they'd like to get rid of, let me know. I can paypal you for it along with the cost of shipping.
Thank you for your help.
Race Pages - 1999 Jeep Cherokee License Plate Bracket Stock Replacement
Jeep Parts, Jeep Accessories & Jeep Soft Tops From The Jeep Parts Experts - Quadratec
Also, along with the plate question, I have a "stereotypical" new owner question regarding tire sizes.
Will I run into any serious fitment issues running a 235/75/15 tire on a stock suspension? The suspension does not appear to have any serious amount of sag in the rear.
I look forward to turning this machine into a great ski-weekend hauler!
Thank you,
Chris
UNHCLL is offline   Reply With Quote
Old 11-20-2009, 09:30 PM   #2
Kettles
Kettles's Avatar
I dont know about the pictures but teamcherokee has one that is listed for all years. Team Cherokee: Search Results the bottom listing is the bracket. Right above it is the screw set for the front bracket.
Worse comes to worse you could just use a few self drilling screws to hold the bracket to the bumper.
And I am running 235/75/15's with no problem (I was before my BB too), as are many others.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output Pictures Build Thread
"Live Free Or Die; Death Is Not The Worst of Evils."
-General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline   Reply With Quote
Old 11-20-2009, 09:42 PM   #3
Fire-XJ
1982 CJ2A
I used 3M double stick tape across the top edge of the plate and stuck it to the bumper. Works like a charm. Had not budged through ice, snow, heat, car washes....
Fire-XJ is offline   Reply With Quote
Old 11-20-2009, 10:54 PM   #4
Mickey_D
The Great White Ghost
Mickey_D's Avatar
I've got 2 plates on the front (state and MIA/POW), both I drilled two pilot holes per plate and used self tapping screws.
I'm running 235/75/15 Uniroyal Liberator AT's on stock suspension that's sagged quite a bit with no problems.
A big thank you to whomever sponsored my membership!!
1974 CJ-5 258 3spd SOA on 31's [Sold in 1991]
1995 ZJ Limited 5.2 on 31's [Sold in 2009]
1990 XJ Laredo 4.0, nothing special [Sold in 2010]
1955 Willys CJ-5 #12171 [Sold in 2011]
1997 ZJ Limited 5.2 The Great White Ghost
1953 Willys M100 trailer
Mickey_D is offline   Reply With Quote
Old 11-20-2009, 11:31 PM   #5
bmyohn
Youngin'
bmyohn's Avatar
i may have my old stock license plate bracket that i would sell to you. i can check tomorrow to see if i still have it laying around the garage or not.
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 11-21-2009, 11:13 AM   #6
Paradise XJ
Consarn it!!
Paradise XJ's Avatar
1990 XJ Cherokee
Try this:
84-01 Jeep Cherokee XJ N0S! Front License Plate Bracket:eBay Motors (item 200407817784 end time Nov-25-09 18:53:00 PST)
Meanwhile, just wire it to the grill to keep it legal.
I have 2 RENIX 4.0 Jeeps
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Originally Posted by fedx95 View Post
Try grabbing it and yanking and see if theres any play.
Paradise XJ is offline   Reply With Quote
Old 11-21-2009, 11:21 AM   #7
UNHCLL
Junior Member
Thanks for all the quick reply's!
Paradise, if you do find the front plate mount, drop me a private message.
Thank you,
Chris
Old 11-21-2009, 02:46 PM   #8
Johnny1953
MY Jeep has P215/75/15 listeed on the door as the stock size, I'm running p235/70/15 with no promblem, I wanted a little wider but no taller & this was as close as I could come, here in Tn. you had better watch ypur speed, because all of these little town's & citys are using cameras to get you with.
Johnny1953 is offline   Reply With Quote
Old 11-21-2009, 05:51 PM   #9
oderalxjlaredo
I just ziptied mine to the bottom of the grill. It's working fine so far
oderalxjlaredo is offline   Reply With Quote
Glock Forum
