NEW OWNER- 1996 Cherokee - JeepForum.com
post #1 of 2 Old 07-21-2011, 07:36 PM Thread Starter
MikeSkSpeed
What's up everyone? I just purchased a 1996 Cherokee 2wd with the 4 litre and I want to know what to look out for problem wise. Is there anything that needs to be checked as far as suspension? What should I be aware of engine wise? It has about 140,000mi on motor and tranny (auto). Im starting by replacing the fuel filter, air filter, plugs, wires, cap and rotor, oil, flushing the coolant system, replacing the belt, gear oil and all fuel lines and brakse parts. The 4Litre's take light oil, correct? The exhaust needs some work as well. Im going to replace the exhaust manifold gasket and install a new muffler. Any input would be appriciated! Thank's guys!!!
MikeSkSpeed is offline
post #2 of 2 Old 07-21-2011, 07:46 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Sounds like a good start to me. I would also consider the rear differential fluid and transmission fluid. As for the suspension I would just make sure all the control arm bushings, swaybar bushings, and shocks and shock bushings were in good shape along with the tierods, balljoints and hubs. I would also check to make sure the exhaust manifold/header isn't cracked down where the two main tubes connect to the collector.
xjfever is offline
cherokee , exhaust , jeep , lifted , repair
Please Someone Help Me With My 1996 Cherokee CoastieJim XJ Cherokee Technical Forum 6 05-27-2011 07:52 AM
NEED ADVICE!!! 1984 Cherokee or 1996 Cherokee Renosausage XJ Cherokee Technical Forum 14 01-23-2011 11:45 AM
1996 cherokee (more problems) WMGilmer XJ/MJ Cherokee Non-Technical Forum 7 05-20-2010 02:22 PM
New 1996 Jeep Cherokee County (Red)XJ owner......Hi!! Bullshot XJ Cherokee Technical Forum 16 04-19-2004 04:31 PM
Help with my 1996 Cherokee Knowklew XJ Cherokee Technical Forum 4 02-27-2003 08:51 PM
