new member; lack of power - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > new member; lack of power
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 02-28-2008, 06:51 PM   #1
Jebusama
1987 XJ Cherokee
hi all, been registered for a while, but i got rid of my last jeep and now am back in another. i can't quit the jeeps i guess. anyways, my 87 4.0 5spd just seems really slow to me. i can't climb off-road without putting it in 4lo and crawling. this is my first 5speed so please tell me that's not why. it also will die a lot when i first try to take off and sometimes on corners/bumps. i've been so frustrated i've thought to get rid of it but i would really like to fix it and start playing too!!
thanks for any help! hope to maybe meet some of you in my area? roseburg, or
Jebusama is offline   Reply With Quote
Unread 02-28-2008, 07:27 PM   #2
xjfever
1995 XJ Cherokee
maybe it's time for a tune up. new plugs wires dist cap rotor button air filter fuel filter? how many miles are on it?
xjfever is offline   Reply With Quote
Unread 02-28-2008, 08:58 PM   #3
Irongrave
fix for no clicks
welcome, not sure one the slow part but a good tune up like posted before then go from there
2006 Ram 1500, towhore, intake tune 285 70 17 KM2s 2001 18' Parker, crawler hauler
1997 TJ, Dad's Claytons 4:88s and stuff A TJ for Dad
1992 YJ crawler, getting 60s. Build thread the illusion of progress
North Jersey Jeep Club, AtoZ Fabrication, Rozzo Fabrication
Irongrave is offline   Reply With Quote
Unread 02-28-2008, 10:03 PM   #4
srmitchell
Try fuel system cleaner, new plugs, wires, everything.
I put new plugs in mine, and it made all the difference in the world.
Not to mention the old plugs were gapped about .025 inches off. haha
I have an xj and it is blue
srmitchell is offline   Reply With Quote
Unread 02-28-2008, 10:39 PM   #5
Jebusama
1987 XJ Cherokee
hey thanks for the pics fix there. i'll try to get some better ones to show off my custom bumper. about the problem, i've done most the usual tune up stuff already, also replaced fuel filter, tried running heet and fuel injector cleaner and octane boost. tried running premium too. one person has suggested fuel pressure and another distributer problems, could this be a timing issue? i haven't had any backfires. is there a way to check fuel pressure? it currently has 202k miles
Unread 03-01-2008, 08:06 PM   #6
Jebusama
1987 XJ Cherokee
could the power lack i'm feeling be from having auto trannys before and now having a manual? i know there is a different gearing there but i have no real understanding of how they relate to each other? with the 5 speed and 31s should i try to switch the gearing? how hard/costly is that? i do have pretty much no 5th gear power, useful for going down hills only....
Unread 03-01-2008, 09:02 PM   #7
1990JEEPXJ
1990 XJ Cherokee
maybe for the gearing you could get some axles from an auto cherokee in a junkyard with 3.55 gears. yours probably has 3.07
My POS
1990JEEPXJ is offline   Reply With Quote
