new to the jeep world. enigine pull question - JeepForum.com
post #1 of 11 Old 01-05-2012, 08:21 PM Thread Starter
jcwc54
2000 FSJ Cherokee
Ive got a 2000 Cherokee 4x4 4.0L. I'm removing the motor to replace it due to piston problem and want advice on the best way to yank this thing. I'm down to the long block everything else is off, now i've her conflicting stories: 1) yank out attached to tranny and 2) disco from tranny then pull motor. Whats the easiest but also safest way. I've pulled a bunch of chevys but never a jeep just curious.
jcwc54 is offline
post #2 of 11 Old 01-05-2012, 10:45 PM
altrocker1
you can pull it without the tranny connected...pulls out easier, but there is a bolt or two that is a pain on top of the tranny...if you pull it all out together, they you have to disconnect linkage, cables etc
altrocker1 is offline
post #3 of 11 Old 01-06-2012, 04:26 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pull just the engine. Support the front of the trans with a floor jack. Remove the top two bell housing to engine bolts before loosening or removing any of the others.
cruiser54 is offline
post #4 of 11 Old 01-06-2012, 04:32 AM
FairlanePhil
FairlanePhil's Avatar
My vote
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline
post #5 of 11 Old 01-06-2012, 05:27 AM
automan2164
1986 MJ Comanche
I usually pull the whole thing, trans and all. But that's just me. I remove as little as possible, pull the front clip, and slide that monster out. I like it a lot better tearing everything apart on a stand or the floor rather than in the Jeep.
Rob
'86 MJ 2.1L 4x4 MT LWB - Factory Diesel
'87 MJ 4.0L 4x2 AT LWB - Metric Ton
'97 XJ 4.0L 4x4 AT Country
automan2164 is offline
post #6 of 11 Old 01-06-2012, 09:03 AM Thread Starter
jcwc54
2000 FSJ Cherokee
thanks guys i appreciate it and am sure I'll have more questions along the way.
jcwc54 is offline
post #7 of 11 Old 01-06-2012, 10:32 AM
Diamond-x
1991 XJ Cherokee
Do you need to work on the trans? If not, just pull the long block.
Diamond-x is offline
post #8 of 11 Old 01-06-2012, 11:38 AM
xj4thewin
Pull the engine by itself, I rebuilt mine this last summer, there's two bolts on the top of the bell housing like cruiser said, theirs a pain but less of a pain then removing the block with tranny to me.
92 XJ
My XJ Build
http://www.jeepforum.com/forum/f11/xj4tw-92-build-up-1182746/
xj4thewin is offline
post #9 of 11 Old 01-06-2012, 01:44 PM
Diamond-x
1991 XJ Cherokee
If you remove the motor mounts and then lower the engine slightly, you can reach the top two trans bolts.
post #10 of 11 Old 01-08-2012, 06:51 PM Thread Starter
jcwc54
2000 FSJ Cherokee
got my block out and apart found blown up piston skirt in cylinder 3. Is this a common failure point? Also I will be rebuilding the motor seeing the only damage was to the piston itself and the motor had 170K on it made it seem like the best option. I have heard something about a particular head gasket to use on the rebuild, Anyone else hear this and what is it that is best to use? Also when I pull the distributor out of the block how do I ensure I get it back in for timing considerations?
jcwc54 is offline
post #11 of 11 Old 01-09-2012, 08:46 AM
xj4thewin
When I rebuilt my motor this is what I referenced for the timing.
http://www.angelfire.com/my/fan/dist_index.html
Its actually really hard to not get the timing right with the 4.0l
92 XJ
My XJ Build
brakes solid while enigine is off but goes to the floor when running matmatt50 XJ Cherokee Technical Forum 2 06-22-2009 02:12 AM
enigine lift 1"? wojtizzlator XJ Cherokee Technical Forum 14 03-30-2007 11:38 AM
So I'm out of the Jeep world... anony91xj XJ Cherokee Technical Forum 2 02-26-2007 05:37 PM
Enigine Swap... nicexj XJ Cherokee Technical Forum 10 03-25-2006 12:56 PM
Enigine block warmer tonedef131 MJ Comanche Technical Forum 7 11-14-2005 04:38 AM
