New jeep owner with fuel problem and codes - JeepForum.com
post #1 of 11 Old 02-13-2011, 05:20 PM Thread Starter
BMWM1
Hi, 1st post 1st jeep. I picked up a new toy to play with today that sort of runs hoping some one might be able to help with where to start with current problem.I picked it up for $500 its a 1998 Jeep laredo wont start unless I use starter fluid or dump some fuel intake but once started it runs great but wont re start untill I do the same thing again. Previous owner has thrown $$ at it with parts before giving up and selling it to me. I get code PO 443 and code p1282. Where would you start and or whats your thoughts thanks
BMWM1 is offline
post #2 of 11 Old 02-13-2011, 05:32 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The P1282 is a short in the fuel pump relay circuit. The P0443 is a short in the evap purge solenoid circuit.
xjfever is offline
post #3 of 11 Old 02-13-2011, 05:53 PM Thread Starter
BMWM1
Ok cool sounds like parts may not even be needed? probably put something back together wrong. Maybe? Where are these two area located and Ill stat checking wires etc in area
BMWM1 is offline
post #4 of 11 Old 02-13-2011, 05:56 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The fuel pump relay is located in the power distribution center under the hood(the black box with fuses and relays). You may have a sticky relay causing the problem. You can trace the wiring from there to the pump located in the fuel tank and check for any problems along the way. You may be able to swap the fuel pump relay for another one in the PDC and get it to start on it's own, this would confirm a relay issue.
xjfever is offline
post #5 of 11 Old 02-13-2011, 06:00 PM Thread Starter
BMWM1
I part out BMWs for a living so i gotta lot of relays dont know if there correct owns but may ha parts here. Thanks Ill get on it now
BMWM1 is offline
post #6 of 11 Old 02-13-2011, 09:06 PM Thread Starter
BMWM1
Relay seem to be ok I swaped them out is the truck siphoning fuel once i get it started?
BMWM1 is offline
post #7 of 11 Old 02-13-2011, 09:08 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
If you turn the key to the on position can you hear the pump run for a couple of seconds?
xjfever is offline
post #8 of 11 Old 02-13-2011, 09:27 PM Thread Starter
BMWM1
I did at one point then it stopped making noise
Does it cut off at a certain pressure
BMWM1 is offline
post #9 of 11 Old 02-14-2011, 06:16 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I would get a fuel pressure gauge on the schrader valve and do some testing. That might yield a clue.
The engine needs a certain amount of fuel pressure to start. You may be experiencing severe fuel pressure drop as the vehicle sits.
49 psi is the idle spec for a 98, plus or minus 5 psi.....that should be verified as well.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #10 of 11 Old 02-14-2011, 06:22 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Runs for 2-3 second at key on no matter the pressure. Sounds like you have a leak down problem. Bad check valve in the pump
To verify, turn the key to run for 3s at a time about 5 times then attempt to start it.
ratmonkey is offline
post #11 of 11 Old 02-14-2011, 05:48 PM Thread Starter
BMWM1
you guys are great thanks for the help plan on doing more testing tonight. Will inform with new details asap thanks again.
BMWM1 is offline
1999 Jeep Cherokee fuel problem Shanker67 XJ Cherokee Technical Forum 5 10-06-2010 10:43 AM
Fuel Injector Wiring Color codes blessup XJ Cherokee Technical Forum 1 03-17-2009 07:53 PM
Jeep Codes Question (Not OBD Codes) crcashman XJ Cherokee Technical Forum 2 12-07-2008 02:20 PM
Needs some help guys jeep shut off fuel delivery problem? Tapout XJ Cherokee Technical Forum 0 06-11-2008 07:44 AM
Another jeep Fuel pump problem Whatsthedeal321 XJ Cherokee Technical Forum 9 04-10-2007 11:02 PM
