#16 | |
The Cone filters do sometimes make a whistle sound. I know my K&N cone does at certain rpms...I kinda like it
![]() EDIT: Oh and I was also going to mention that I did roughly the same thing to catch the blowby. I just installed a T-fitting with a bottle and a filter coming off of it while the other end went to the crankcase. Works really good!
[SIZE=1][URL=http://www.cardomain.com/id/koenig1]1989 Jeep Cherokee Laredo [I]"Betsy"[/I][/URL] ~147,000km, 4.0l, AW4, K&N custom cone intake, Dark Cordovan Pearl Metallic in color, 4 Dr. w/ chrome trim.[/SIZE] |
#17 |
Everyone I know running a K&N has that whistle. . . in the case of my roommate's new 4Runner, it improves his throttle response like mad.
'94 XJ Sport 2dr. '86 MJ '42 Willys MB |
#18 |
this will work fine if your not running a cat-if so it will stop it up like crazy. At least with suction coming of intake it gets burned. But do not do this if you have a cat. edit- this is talking about the moroso scavenging kit. I was able to fix my blow by problem just replacing a lot of clogged vaccum lines. I tried to go to a larger size on the vac lines I replaced too.
1988 red 4 door XJ 4.0, AW4 Command-Trac 3" Skyjacker Softride with AAL and Nitro Shocks 30x9.5 ProComp All-Terrains Hella H-3 100watt bulbs in factory fogs(upgraded wire) 50x4 Pioneer Head Unit and Pioneer 5.25" rear and Infinity Kappa 4" front 10" Infinity BassLink; Cobra CB 4' Firestik II (USA limited) Dana 30 front, Dana 35 rear, NP231 [SIZE=1]next mods are lockright front, SYE conversion, and BB![/SIZE] |
#19 | |
How would this set up clog a Cat? That line is a clean air induction line that allows clean air into the engine and back through the PVC line. I think the main issue with the manufacture set up is they put the hose connection on the intake air tube where vacuum is probably slightly higher because of faster moving air. I would have bet if they would have mounted the line say at the rear of the air box it wouldn’t cause this reverse flow of air.BTW: I took my line completely off and installed a chrome breather cap and clean my PVC line more often. I probably don’t intake the cleanest air possible but that what oil changes are for.
Mods 2006 Jeep Wrangler X, 4.0 4:11 gears '90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank A/C Conversion/Home Built Roof Rack/K&N Box Filter Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer Jeep Pic's |
#20 |
Before I installed the can, I had a breather element, just like the one on the can, installed where the PCV line attaches to the valve cover. It worked okay for awhile, but then started spewing oil out of it and all over the engine bay. I've kept all my vacuum lines, etc. clean, but it still insisted on spewing.
Once I am comfortable with this setup, I am going to run a line from the can (where the breather element is now) to the air tube and eliminate the breather element altogether. The good thing about this setup is, there ain't no more oil blowing all over the place!! Odd thing is, since I've done this, there has been hardly any residue deposited in the can... ![]()
Leave no bolt unturned... 1998 ZJ Laredo 4.0 IL6 42RE Tranny 242 TC No mods yet... still fixing PO screw ups |
#21 | |
probably should also be intalled post 02 sensors as well
98 TJ 4 Banger, lift, tires... blah blah blah (wifes DD) 86 XJ 2.8 V6, 4 barrel carb, lift, tires... blah blah blah 61 CJ6 4 Banger, PTO winch, Stock, Rusty 00 F250 Diesel 4x4, To the trail hauler. Several others. Mostly Fords. |
#22 |
Could someone elaborate on how this mod can hurt the CAT and/or the O2 sensor?
How does moving the PCV filter from the airbox to it's own external filter change anything? As long as the return line is still going to your main intake for a vacuum source...??
#23 | |
This can I'm using has no way of doing that.
#24 |
Ok that's what I was thinking...somehow we got talking about different mods
Thanks!
#25 |
"Blowby Buster" is working!
I've been running this can for better than a week now and it is working great! Surprizingly, I haven't even had to empty it yet - there is hardly anything in the can. I'm not quite sure why the blowby has been reduced so radically, but I'm not complaining!
Hmmm, maybe I should put a few of these up on ebay... ![]()
#26 | ||
I think because the original vent line is connected to the intake induction system, the vacuum draw from the intake pulls oily moisture from the valve cover. When originally this line is suppose to provide a sealed access of clean air to the engine that eventually circulates back through the CCV port. Thus adding to the problem is the 2mm CCV hose that is up against the 1/2" inlet line that happens to be plugged into the air induction system.
#27 | |
Take a spay can and spray it into a small cup as if you were going to brush it onto something.. Take a long spray to make a puddle.. When the oil is misting and blowing around in the wind it'll seem like alot more then when it is captured and contained.
99 XJ sport, Black, 4 door, 4 litre, 4wd Black Jeep club member # 99 ASE Certified and professional Auto technician 12+ years Every rose has it's Thorn, every XJ has it's leak, and every cowboy sings a sad sad song |
#28 |
Hey xj4play,
Can you give us an update, is your mod still working? If so I'm gonna give it a try.
88 XJ Laredo 4.0 AW-4 NP231 235's Homemade tow bar mount Factory tow package '98 29 Spline Chrysler 8.25 Rear axle |
#29 |
To The Top!
#30 |
ya, thats definatly a good way to do it. Better than what I did with my YJ, which was run a 4 foot tube off the engine, figured it'd shoot it all out, and never considered the filter would effect it.... well, thats why I sold it.
Actually alot of semi's run their blow by tubes off the side of their engines. That sound you hear when throttling hard on an pen air: filter is the resonance of the valves "wistling" air into the piston. I say resonance because it can only be heard at certain Rpms/throttle.I like it alot, but I'd want something that didnt look like I had a pint of primer paint in my car.
95' Jeep Cherokee, 4.0, 3.5'' lift, 31x10.50x15 crawler rims. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
