Quantcast New invention, old problem... - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > New invention, old problem...
Free Shipping on TIRES at KrawlOff-RoadSpartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 03-14-2005, 12:44 PM   #1
xj4play
In my continuing futile efforts to keep the oil on the inside of the engine, I finally gave up trying to thwart the blow-by monster. Okay damn it, if you need to throw my oil out of the crankcase, at least I'm gonna tell you where to throw it!!
Sooo, I created a catch can for the blow-by residue to land in. This will work on '87-'90 4.0's, fitted with a cone-type air filter (airbox removed).
I went to Lowes, bought an empty quart-sized paint can, a couple of 3/8" right angle brass hose fittings, a 1/2" copper tubing elbow, a 3/8" straight hose fitting and a length of 3/8" hose. Also needed are 1 grommet (brand: HELP! Part # 42059) and 1 APC Breather filter, both available from Advance Auto Parts.
First, drill two 1/2" holes in the sides of the can toward the top lip, opposite each other. Install the right angle fittings in the holes by soldering - one with the nipple facing straight up, and the other angled at 45 degrees.
Next, solder the straight hose fitting into one end of the elbow (a little grinding may have to be done to get it to fit). Install the grommet in the front hole of the valve cover. Fit one end of the hose to the straight fitting and insert the other end of the hose on the angled fitting of the can. Insert the other end of the elbow into the new grommet on the valve cover. I sealed the grommet and elbow junction with Permatex.
Now install the breather filter on the other fitting of the can. Sit the can on the inner fender where the old airbox used to be.
I painted the assembly with Rustoleum hammered black paint. For now, it is just sitting on the inner fender, but I plan to mount it and install a petcock to drain it. To empty it right now, I have to disconnect it and pop the lid off to dump it out. Yeah, it's a bandaid, but at least it keeps the engine bay dry.
I'll post pix as soon as I can get some shots of it.
Leave no bolt unturned...
1998 ZJ Laredo
4.0 IL6
42RE Tranny
242 TC
No mods yet... still fixing PO screw ups
xj4play is offline   Reply With Quote
Old 03-14-2005, 02:37 PM   #2
ddoffroad
thats awesome...im looking to do something like that on my 93 ZJ. Do you have any pics of that assembly.....?
Thanks,
DDO
99 XJ - 4.0L HO, Rusty's K&N Intake, Rusty's 4.5" full suspension, 31x11.50 Swamper LTB's, 15x8 blk Daytona's, clear lenses, Warrior bumper w/ hooks
Down & Dirty Offroad: http://ddoffroad.com/
My XJ site: http://www.cardomain.com/ride/2488225/
My Old XJ Site: http://www.cardomain.com/ride/2058746
ddoffroad is offline   Reply With Quote
Old 03-14-2005, 02:49 PM   #3
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
I wonder if you could just dump the oil back in?
Nice idea.
Kyle - I tag stuff®
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline   Reply With Quote
Old 03-14-2005, 03:42 PM   #4
thackney
Nice write up. Can't wait to see the pictures of it.
thackney is offline   Reply With Quote
Old 03-14-2005, 03:44 PM   #5
Dvs_Lance
I thought I had a blow-by problem and was going through air filters like crazy. Replaced the lines coming off the valve cover, and it hasn't gotten oil on a airfilter since. Just thought you might like to know
1988 red 4 door XJ 4.0, AW4 Command-Trac
3" Skyjacker Softride with AAL and Nitro Shocks
30x9.5 ProComp All-Terrains
Hella H-3 100watt bulbs in factory fogs(upgraded wire)
50x4 Pioneer Head Unit and
Pioneer 5.25" rear and Infinity Kappa 4" front
10" Infinity BassLink; Cobra CB
4' Firestik II (USA limited)
Dana 30 front, Dana 35 rear, NP231
[SIZE=1]next mods are lockright front, SYE conversion, and BB![/SIZE]
Dvs_Lance is offline   Reply With Quote
Old 03-14-2005, 08:37 PM   #6
ssnsltd
I did the same thing with a plastic can myself before I rebuilt the engine.
FYI on Blow-by.
On all three of the 4.0l engines I took apart, the head on all of them had some of the oil drain passeges blocked/gummed up. The block that had it the worst had ALL of the passages clogged. I would encurage you to take the valve cover off and clean these out. At highway speeds, the oil just builds up in the valve cover turning the PCV and Air Cleaner into a snorkle and the engine just sucks the oil out.
'87 with 193k and '88 XJ with 153k
ssnsltd is offline   Reply With Quote
Old 03-15-2005, 05:28 AM   #7
xj4play
Here are the pix...
...as promised...
Not very fancy, but functional!
Installed where the airbox used to be...
The hose from the valve cover to the can...
1998 ZJ Laredo
4.0 IL6
42RE Tranny
242 TC
Old 03-15-2005, 05:32 AM   #8
xj4play
FYI on Blow-by.
Yeah, been there, done that... passages are clean. This thing has 261K on it, so I know it needs rings. This can thing is just a temporary "diaper" until I can get a rebuild done.
1998 ZJ Laredo
4.0 IL6
42RE Tranny
242 TC
Old 03-15-2005, 06:49 AM   #9
thackney
Thanks for posting the pics.
I'll be doing the same here this spring.
Old 03-15-2005, 08:47 AM   #10
jlayne
cool i know some guys that do the same thing, it works great... i have one of these on my jeep it is a
crank case scavaging kits this site shows it on a car, but you'll get the idea.. it creates a negative pressure in the engine and should solve the problem.. plus it blows all the goo out the exhaust.. me 2.8 blew out 2 rear mains before this.. since then.. not a drip
98 TJ 4 Banger, lift, tires... blah blah blah (wifes DD)
86 XJ 2.8 V6, 4 barrel carb, lift, tires... blah blah blah
61 CJ6 4 Banger, PTO winch, Stock, Rusty
00 F250 Diesel 4x4, To the trail hauler.
Several others. Mostly Fords.
jlayne is offline   Reply With Quote
Old 03-15-2005, 12:34 PM   #11
ssnsltd
Hmm, nice job. The gizmo I put in did not have the filter, I ran a hose back in to the air cleaner intake like on the stock system.
Old 03-15-2005, 01:13 PM   #12
xj4play
Yeah, I was going to do that and still might - I just want to see how much crap this thing collects before I run a hose to the cone adapter. I did something similar with an oil bottle when I still had the stock air box on it. It caught alot of the blow-by, but still managed to screw up one end of the air filter. I don't want to mess up my K&N!
1998 ZJ Laredo
4.0 IL6
42RE Tranny
242 TC
Old 03-15-2005, 01:14 PM   #13
Dana44
Hm, When i put a cone filter on my MJ (cuz its got the same engine), i had no problem with blow-by, i just stuck a little PVC filter/venter thing, and left it at that, works good
do you get a whistling noise when you take off? or driving?
Dana44 is offline   Reply With Quote
Old 03-15-2005, 01:18 PM   #14
xj4play
No, not so far...
1998 ZJ Laredo
4.0 IL6
42RE Tranny
242 TC
Old 03-15-2005, 01:20 PM   #15
Dana44
Originally Posted by xj4play
No, not so far...
hm, because my friend put a intake and filter on his jeep, and when you shift it whistles, the intake that is.
Glock Forum
