New here.... Wanting opinions on rear diff swap (mitsubishi 9.5 in. Diff with locker) - JeepForum.com
post #1 of 32 Old 08-23-2013, 01:57 AM Thread Starter
Tonygon
1992 XJ Cherokee
Hi all!!! New here on the jeep page. My wife owns a 92 xj 2wd with roughly about 4.5 in lift. I know alot of people wont encourage a lifted 2wd but here it goes. This rig is mostly used on city but plan on light wheeling with the family like camping trips and such. Any disadvantages or cons in having a full selectable locker in the rear since i obviously dont have low range gearing? I would be using a montero diff like the one on my 88 montero that is selectable air locker. I love that thing!!!! Yes i know its 6 lug so i would have to deal with somehow converting front to 6 lug if i want matching wheels. It would have 4.63 gearing. What size tires are appropriate for this set up? Thanks in advance!
Tonygon is offline
post #2 of 32 Old 08-23-2013, 07:35 AM
gs69350
Go for it
1998 Jeep Grand Cherokee 5.9 Limited - Stone White - Stock for now.
<-- 5.9 Owner's group on FB.
gs69350 is offline
post #3 of 32 Old 08-23-2013, 09:15 AM Thread Starter
Tonygon
1992 XJ Cherokee
Thanks for the encouragement, gs. Also i forgot to mention, i would also aquire rear disk brakes
Also ive searched and read about converting a front dana 30 into 6 lug. Would the knuckles on my 2wd xj be the same size as the ones on the d30? I know nobody has done this to the front, but i bet a ton of you on here have messed with the mentioned parts a lot and might have an idea. Im working on a full size roof rack at the moment so i'll share some pics shortly!!! Thanks again guys.
Tonygon is offline
post #4 of 32 Old 08-23-2013, 12:11 PM
gs69350
I don't know anything about the unit you are planning to use, but 9.5" sounds bigger, therefore stronger than the common swaps. You'll be on your own as far as tech support on it (at least in this forum). If the axle tubes are similar to 8.8 you should be able to get the brackets you need fairly easily without too much custom fab. You'll have to get creative and find the proper u-joint to use or have custom driveshaft made (which you might need anyway if the unit is bigger than your current). Gears are a bit steep unless you're running 33 or 35's (just my opinion).
Go do it, take pics, and make a write up.
gs69350 is offline
post #5 of 32 Old 08-23-2013, 12:29 PM Thread Starter
Tonygon
1992 XJ Cherokee
Yes that diff is super beefy!!! Its coil set up stock. The one on my 88 montero i had to shave down and weld perches to so i know about all that. Thanks for answering my questions about gearing and tires. I would like to keep it simple and cheap so i want to stay with 31 in tires. So i will try to find a unit with the 3.9gearing which was available on monteros. I want to keep it junk yard cheap like my other rig which is super capable. Im still thinking about it, if i decide to do it i'll post a bunch of pics. Thanks a lot. Anyone else have any input on this? Constructive criticism is most appreciated!
Tonygon is offline
post #6 of 32 Old 08-23-2013, 02:13 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
Why rear is in the jeep now? I'm not sure when they started putting in the 8 1/4 but if you have one they are pretty beefy and will hold up to being locked, wouldn't it be easier to just buy an arb air locker and install it to keep things simple. I like complicated projects myself sometimes however I'm NOT allowed to touch the wifes jeep, well not yet. It will take alot of work finding all the right parts and makeing things it right but I don't see why it cant be done.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #7 of 32 Old 08-23-2013, 02:44 PM Thread Starter
Tonygon
1992 XJ Cherokee
It ncurrently has the d35 like i said im cheap, the mitsu axle comes STOCK with an air locker! I can get that at the yard for less than $100 on half off day! The whole shaving of the tubes and welding perches is simple work. An ARB unit is pricey no matter what diff. Ive had the mitsu locker on my truck for years now and works awesome. It comes with a low pressure air pump to activate it. Any ideas on converting a 2wd front axle into 6 lug? I know that sounds so stupid!!! Investing time and money on an axle with no gears in it!!! but a 6 lug xj would also look awesome. Im think it would perform well off road with this set up? Thanks a lot for your input, buddy
Tonygon is offline
post #8 of 32 Old 08-24-2013, 10:13 AM
bobthecatkiller
How about a 8.25 with LSD, for camping and such I don't think you will need much more, and they came stock on some xjs. just a idea.
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #9 of 32 Old 08-24-2013, 10:47 AM Thread Starter
Tonygon
1992 XJ Cherokee
Thanks for the suggestion. I upgraded from lsd to full locker on my montero and completely fell in love! I actually have an lsd on the jeep's dana 35 now.
On my montero i have driven through some good stuff on 2wd locked and its far better than lsd. Sure lsd would probably suffice for a family camping trip, but i love the locker and ill also get disk brakes.
Tonygon is offline
post #10 of 32 Old 08-25-2013, 02:00 AM Thread Starter
Tonygon
1992 XJ Cherokee
So im seeing the posibilities and i might be able to regear the mitsu axle with junkyard gears to 4.22s. Would you guys say that would be good for 31 inch tires?
Tonygon is offline
post #11 of 32 Old 08-25-2013, 10:58 AM Thread Starter
Tonygon
1992 XJ Cherokee
Anyone?
Tonygon is offline
post #12 of 32 Old 08-25-2013, 11:03 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Whatcha gonna do when you get a flat? Carry two spares?
Personally I think that the money would be better spent upgrading to 4wheel drive.
Luck Favours The Prepared
Anticanman is offline
post #13 of 32 Old 08-25-2013, 11:28 AM Thread Starter
Tonygon
1992 XJ Cherokee
Like i said before. I would convert the front to 6 lug if i pull the trigger on this. Thanks for your opinion but its my wife's truck and she doesnt need 4wd. You seem experienced, what do you think about 4.2 gear ratio and 31's? Thanks
Tonygon is offline
post #14 of 32 Old 08-25-2013, 11:43 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That gear ratio seems quite low. I have a 4.0 but have the manual transmission and run 4.10 with my 35's on the freeway. I had 31's with the low gear ratio and burned through fuel like no other.
post #15 of 32 Old 08-25-2013, 01:18 PM
bobthecatkiller
There's a chart around here somewhere, 4.10s and 31s is getting to low but still not terrible. I think for a xj 3:73 is about stock with 31s.
Edit: http://www.jeep4x4center.com/jeep-ti...atio-chart.htm
