New Here - JeepForum.com
post #1 of 7 Old 06-26-2005, 01:35 PM Thread Starter
88JeepLimited
New Here
Hey everyone,
I have an 1988 Jeep Cherokee 4X4 with the 4.0L 6. It currently has 294,xxxmiles onit. IT runs strong but i was wondering if it is worth puttin a lift on it. It has plenty of power offroad but on the street it seems to lag. If i put a lift, say a 3.5 of 4.5 lift on it i would have to run bigger tires correct? Wouldnt this make the car lag even more? WEll sorry for so many questions but i really would like to know. thanks
88JeepLimited is offline
post #2 of 7 Old 06-26-2005, 02:07 PM
sizzle-chest
sizzle-chest's Avatar
if you put a lift on yer riggins, then you dont need bigger tires, but you will want them so that it doesnt look like ell. Plus, there aint much point to a lift without tires really. Some things to consider before lifting: you got a lot of miles, how long will your rig last after putting money in to lift it? Once lifting it, it will not be as road worthy, i dont know about lag because that sounds like something else, but it wont be driving better on the road for sure. Also, you cant just lift it and expect to be done with it. Look up death wobble under search to find out how many things you may have to correct with a simple lift. Lag like your describing could be indicative of some very serious problems. Ide figure those out before putting a grand into lift and tires.
sizzle-chest is offline
post #3 of 7 Old 06-26-2005, 02:29 PM
cherokee xj
^^^ i think thats the most knowledgable and serious comment i've seen sizzle write. Way to go
stock 2000 Cherokee Sport
black 4 dr.
cherokee xj is offline
post #4 of 7 Old 06-26-2005, 02:54 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
wow......sizzle I......yeah, what he said. lol.
Welcome to the board. IMO, I'd focus on a tune up before a build up. Replace the plugs, cap, rotor, and wires. Remove and COMPLETELY clean the TB. Verify the EGR is in solid operating order. Clean and replace necessary CCV system elbows and tubes. Check and replace if necessary the vac lines.
Get her running like a top, then start to think about how much and what kind of wheeling you will be doing. If your rear leaf packs are in good shape, and you spend more time onroad, consider a simple upgrade to 235 70 r15 tires with no lift. Your springs should be at about 17.5" from the center of the rim to the bottom of the fender flare above the rim. The rear measurement will be 17".
If you plan on wheeling, or the area your wheel requires a hair more ground clearence, then consider a 2" budge boost (bb) lift. There are several write ups in the FAQ/Tech sticky near the top of this page that deal with ways to get some lift. With a bb you can run 30's. That won't kill your power or on road drivability and will offer a hair more ground clearence at the diffs.
It is possible to run 30's at stock lift, but you won't get the maximum benefit of the tires like you would with the extra room to move in the wheel wells. If you want to run bigger tires, it will require either more suspension lift or a sawzaw on eth fenders. Bigger tires will zap the power due to the fact that taller tires will effectively give you less gear.
Feel free to ask any questions here.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #5 of 7 Old 06-26-2005, 03:35 PM
wolfepack215
wolfepack215's Avatar
1987 XJ Cherokee
Wooo Hooo!!! Good Post Sizzle.....
wolfepack215 is offline
post #6 of 7 Old 06-26-2005, 03:55 PM
XJ-NoDough
XJ-NoDough's Avatar
Sizzle, so that's why you are getting yours running good, and installing recovery points and haven't done your budget lift yet.
My DD
'89 XJ Limited
204,XXX miles
Leather, Loaded
4L Selec-trac
Automatic
3"-4.5"ish Homebrew lift
16x8 MB Motoring Rockers
265/75R16(31ish"X10.4") Goodyear Wrangler M/TRs
Trimmed w/ Bushwackers
Stock 3:55 gears
sans big audio
Homebrew intake w/cone filter
"Some people are like a slinky... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs." :my dad
XJ-NoDough is offline
post #7 of 7 Old 06-26-2005, 04:09 PM
wolfepack215
1987 XJ Cherokee
At 294k miles, you are looking at some maintenance items first, and a good chance of a rebuild depending on the history of the motor. Best to spend your money on the maintenance and have a good running machine, than lift it and all so that you can show it off in your driveway cause the motor has cr@pp*d out on you.
Or, second option, Pull the motor, stroke it out, it will need a rebuild soon anyways. While the motor is out to shop, put the lift, wheels/tires, Rockrails, Upgraded axles, regear, SYE, New Driveshaft, lockers, Skids, Front and Rear Bumper(w/Tire & accesory Mounts), Winch, 3 row radiator, Hi-current alt., Light bar, Safari Rack, Snorkel, Stereo, GPS, CB & Whip, On Board Air, Herculine the interior and Line the lower edge of your body panels, Tint the windows, and do a disc conversion on the Rear Axle. ..
Dangitt, got carried away with the lottery winner dream again.......
Yeah, first things first, Maintain, update, modify..... Repeat.
