Quantcast New front Hubs......what a difference - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > New front Hubs......what a difference
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 05-19-2008, 07:05 PM   #1
mfinkler
OK, I figured out my roaring, humm....whatever was not worn out tires, pads or rotors which I replaced all. It was my hubs. I bought this 96 about 18 months ago with 78k on it. I test drove many Cherokees with similar mileage up to about 100k. They all had this roaring sound some a little more than others. This was my first Cherokee 4x4 and it seemed most told me they all sound like that. Well I got used to it but mine got pretty bad the last month or so. There have been a lot of threads lately about this sound and thoughts of u-joints, pinion bearing or gear, tires, rotors etc. If you are having this noise check the hubs!! I'm not sure how long they are supposed to last but I would suspect if you have 80+k on it it a good chance there going bad. Mine has 98k now but this problem was probably starting when I bought it.
I can't believe how quiet this thing is now..........i swear it feels a like a new one. I can now turn my radio down!!
The job is very simple except getting the old hubs off. We even tried a puller but it seemed like it wouldn't pull straight. A hammer, muscle and PB Blaster finally did it.
To diagnose the problem get it at the speed the sound is this worse and turn the wheel left and right. If the noise changes in anyway or stops it's most likely the hubs. Anything in the drive line wouldn't change by turning the wheel. My noise nearly disappeared when I turned to the right and got worse going left. My right hub was the worst of the two.
mfinkler is offline   Reply With Quote
Old 05-19-2008, 07:09 PM   #2
XJRookie
1994 XJ Cherokee
Just out of curiosity: How much were the new hubs? Did you use factory hubs or switch to lock-outs?
Thanks!
1994 XJ Sport
4" ProComp Lift with full leafs
Rock Krawler Wheels/X-treme Mud Terrain 31x10.50
Banks Torque Tube w/Dynomax Super Turbo Cat-Back
K&N Fuel Injection Performance Kit
XJRookie is offline   Reply With Quote
Old 05-19-2008, 07:11 PM   #3
mfinkler
I got them at the parts store. $106.98 ea. 1 yr warranty
Old 05-19-2008, 08:11 PM   #4
Texsun
WoW thats cheaper then I expected which auto parts store did you use?
I think I am gonna replace my hubs next
DD 2009 Silver GMC 4door 5.3L on dirty harry wheels
DD 2001 Green Jeep XJ 4.0L 4.88s locked F/R on 35s
Texsun is offline   Reply With Quote
Old 05-19-2008, 08:39 PM   #5
JeepRide
Napa has a 1 year hub assembley for $75.00
98 xj 4.0L 231 t\case off road commode
4 in the floor and a fifth under the seat
Eat more possum
JeepRide is offline   Reply With Quote
Old 05-19-2008, 08:56 PM   #6
okjeeper
1991 XJ Cherokee
Look on ebay you can get the nicer ones for cheaper then a parts store..
okjeeper is offline   Reply With Quote
Old 05-20-2008, 12:00 AM   #7
JWFokker
1994 XJ Cherokee
Link? What exactly makes them better than Napa hubs?
JWFokker is offline   Reply With Quote
Old 05-20-2008, 01:11 AM   #8
jeeper01
Stay away from Ebay hubs, they are trash, remember your life rides on these things. I just changed out the hub this weekend to deter some rubbage, and it took about 45 minutes with a break. Pretty straight up job.
Timken and National Bearing are reputable names, you can also get their cheaper versions from the parts store as well, usually with a lowered price, warranty, and different name.
1998 Cherokee Classic... 2" BB on Moabs
1988 Cherokee Limited... 4.5" RC lift, RK longarms, on 31's. Several homemade skids.
jeeper01 is offline   Reply With Quote
Glock Forum
