#1 | |
New battery or something worse?
Okay, so I guess I will preface this with the fact that I was mudding last week. Took it through some pretty harsh mud because I wanted to get my new stuff dirty.
Drove out, and while I was in the mud I didn't really kill it- just hammered the gas to get threw everything. I drove home fine and left it dirty for the next five or 6 days. Sunday at work I go to start it and get nothing. I didn't leave my lights on or anything. I just put the key in and nothing. So I jump it off a co workers car and it runs fine. I took it to get it washed after that thinking maybe with an undercairge spray and some time on the road to charge the battery it would help. Seemeed like it helped, but today the same thing happened. I left the parking lot and it started fine, no hesitation or anything. I drove home, but left a window down. So I go to turn the accessory on and get nothing. 6 hours later I check it again....and everything is working. Acc works, dome light when I open the doors.... So is it just a battery on the fritz or something more serious? I know I need a new battery soon so it wouldn't hurt. Whats got me confused is that it randomly doesnt do anything two times, but it works fine for 5 days inbetween those times.
#2 |
may have rattled a wire loose, check all your cables on the battery and where they mount to the engine. Clean your terminals too.
1984 Suzuki SJ410, 1.3L 5speed, soft top, spoa, shackles, bodylift, 6 offroad lights. 1988 Dakota, 318, 5 speed, 4.10's, rollbar, lowered 3". 1986 2dr XJ, 2.8, 5 speed, Bushbar, 1989 XJ, 4.0, AW4, NP231, D44, 3.73's, *Stolen* 1987 MJ Sportruck, 2.5, AX5, Rollbar, *Jeep Heaven* 1986 MJ, 2.5, T-5, bushbar, Longbox, *Jeep Heaven* |
#3 |
The terminals are okay. I checked them when I jumped my battery. Guess it wouldn't hurt to check the alt. Will I get any acc power if the connections on the starter are loose?
#4 | |
#5 |
another 01 XJ with power problems... welcome to my world
http://www.jeepforum.com/forum/f11/wtf-killing-my-battery-345612/ |
#6 | |
So before I spend the money, is there a big advantage to having a yellow top? I could buy a battery and go skiing for a day for the price of those things. |
#7 | |
1996 Cherokee 4.0: see left tab 2005 Liberty Sport, CRD: Stock 2003 Tiburron GT [COLOR="Navy"]Colorado Jeep Club Member #68[/COLOR] [COLOR="Red"]Wheelin Vids:[/COLOR][URL="www.youtube.com/siege22"]www.youtube.com/siege22[/URL] |
#8 |
Good to know.
#9 |
Its your negative battery terminal connector. Mine was doing the same thing. Chances are your connector has gotten soft and is no longer getting a good bite. Remove the connector from the terminal than try and take the bolt out. Your next step is to take a hack saw and cut down the seem of the connector effectively opening it back up. once you have done that get a new nut and bolt and tighten accordingly. Doing that will generate much more pressure on the connection site and you wont have all of the arching and poor connectivity. Its a temporary fix but its easy enough to do, to do it right get new terminal connectors.
#10 | |
#11 |
Do the clamp before the battery and drive it for a while. Chances are that the battery is fine. Once the clamp is replaced, watch to see what voltage your charging system is running. If it's charging and running about 14 volts, you should be good.
#12 |
I plan on it, but like I said before I DO need a new battery anyways.
#13 |
Have you had the chance to do your repairs? Im willing to bet your issues should be resolved.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
