Neutral safety switch wiring problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Neutral safety switch wiring problems
20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!Father's Day & Moving Day Sale!
Unread 11-04-2007, 09:09 AM   #1
Racin444
Hey guys
I went to go fix my neutral safety switch on my 1993 Cherokee. Neither back up lights nor starter were working. The switch was shot and needed to be replaced. So I bought one online and turns out that the plug connector is completely different. My '93 has a male end NSS connector with six wires, while the newer model ( im guessing 1997 - 2001) has a female end NSS connector with seven wires.
Ive looked everywhere on the web and couldnt find much of anything to help out. Could anybody help me out with a wiring diagram of some sort. I would like to rewire the new NSS switch with the older male style connector.
Thanks
Jayce
Racin444 is offline   Reply With Quote
Unread 11-04-2007, 09:14 AM   #2
Racin444
This diagram is the only thing i found for the 1987 - 1996 NSS switch
[img=http://img249.imageshack.us/img249/7120/12aai3.th.jpg]
Unread 11-04-2007, 09:20 AM   #3
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
This link has a diagram showing 8 postions and what they do at each postion:
http://www.cherokee-jeep.com/1-2swremov.htm
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Unread 11-04-2007, 09:47 AM   #4
spedly
2011 JK Wrangler
So if i were to want to bypass it I would pull the wires from b&c and solder them together?
spedly is offline   Reply With Quote
Unread 11-04-2007, 09:49 AM   #5
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Yes, but you may get a CEL for trans range selector.
93 Sport
Specs in Profile.
Unread 11-04-2007, 09:59 AM   #6
spedly
2011 JK Wrangler
that bulb "burned" out a long time ago
Unread 11-04-2007, 08:19 PM   #7
Racin444
Ive seen that diagram for the 1987 to 1996 years
All I need is the newer diagram for the 1997 to 2001 cherokee so I can fit the old connector on
Unread 11-05-2007, 09:19 AM   #8
Gsmyth75
1992 XJ Cherokee
My nss crapped out on me too so i just ran a wire to the starter and another one to the batt and got a switch. Who needs reverse lights anyway?
1992 Cherokee Laredo 4.0 L6, Aw4, Dana 30/35, Np242, 201k
Crower p/n 44243 Camshaft, Camsaver High Oiler Lifters, He Pistons .030 Over, Decked Block and MIlled Cylinder Head. Melling High Volume Oil Pump
Flowmaster Super 40/ Cat and Tailpipe Delete, Apn Header, Homebrew Bored Throttle Body, Rustys Cold Air Intake with Spacer
Gsmyth75 is offline   Reply With Quote
Unread 11-05-2007, 09:44 PM   #9
Racin444
Yeah i hear what youre saying
Problem is i already bought one so i need to know how to swap the connectors
Anyone have a wiring diagram for both a 93 NSS switch and a 98 NSS switch?
