Neutral Safety Switch 97 XJ - JeepForum.com
post #1 of 9 Old 09-15-2006, 09:31 AM Thread Starter
catalyst319
I was using the search utility to find information on this topic,but it appears to be down for quite some time. I am trying to resolve an issue with my neutral switch on my 97 XJ, and had to destroy it to get it off of the transmission. There is still a remnant of the original part on the transmission, and I need some advice on how to remove it. I've mobilized the vehicle by overriding the neutral wire so I can start and drive the vehicle, but the check engine light is on, and throw codes relating to the transmission because of the override. I've since purchased a used neutral switch from a '96, which appears to have an identical housing, with one less wire. Is it possible to re-wire it so it will work with my '97?
Bill
Syracuse,NY
catalyst319 is offline
post #2 of 9 Old 09-15-2006, 02:55 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I don't think it should be one wire short. I was under the impression that the AW4 NSS were the same through the different years. Was this a brand new part of a junk yard piece?
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 9 Old 09-15-2006, 05:35 PM Thread Starter
catalyst319
It look like a junkyard/used piece. I know for sure that the wiring plug is different, but I was hoping that there was a way to fool the computer, or at least hook up most of the necesary wires.
Bill
post #4 of 9 Old 09-15-2006, 05:43 PM
GottaBeJeep
Not any help to you, but maybe to me. Why was your NSS difficult to get off? I am trying to take mine off to clean it, but the dang thing won't come off the rectangular post, and I have managed to completely destroy the treaded part around the post, and the NSS still won't come off. I am about to just shatter it to pieces and get a new one, but I still need to get it off that post. Any suggestions? Also, since the search isn't working, how did you bypass the NSS? My XJ won't start at all, and I think it is due to the NSS. I would like to bypass the NSS to see if that is truely the problem.
Thanks for whatever help you may be able to provide.
...Off Road Armor that's "Tough as Scales"
GottaBeJeep is offline
post #5 of 9 Old 09-15-2006, 08:22 PM
mpwal099
mpwal099's Avatar
1997 XJ Cherokee
Ok a for sure answer is that NO the '96 NSS can not be rewired. You can get a brand new one from AutoZone for $229. That is about $150 cheaper than anywhere else.
Mine broke off as yours did and I needed to get a dremel on it t cut it off. If you get some PB blaster on that piece and a big flat head screwdriver on it you may be able to pry it off also. It took me the better part of 6 hours total to do my NSS but that was in the winter without a lift to work under.
If I think of anything else I will add it.
HTH!
MIke
When I die and go to heaven I hope the first thing God says to me is "The bar is right this way."
mpwal099 is offline
post #6 of 9 Old 09-15-2006, 08:25 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Marty is it just the end that won't come off? I had to file that down for it to slide off.
93 Sport
Specs in Profile.
balloo93 is offline
post #7 of 9 Old 09-15-2006, 10:39 PM
GottaBeJeep
It isn't sliding or even moving on that square stub at all. The NSS is moving around the threaded compression fitting on the square stub, but it is not moving out away from the tranny at all. I did the thing Jason showed on his site where you have the large nut slightly turned out and put the screwdriver between it and the NSS and pry gently against the tranny pan, and I stripped the nut right off, taking all the threads off the fitting. If I could just bypass it to make sure the NSS is or isn't the cause of my XJ not starting, then that would save me a lot of time of trying to take the dang thing off.
post #8 of 9 Old 09-16-2006, 06:36 AM Thread Starter
catalyst319
The main housing separated from the flanged part that goes around the square shaft on the transmission. Even the dealer said that it is common for them to get stuck, and they end up using a dremel or cutoff wheel to remove the rest of it. I'm really not happy about the whole experience so far since I couldn't find the part for less than $120. I got a wiring diagram from the dealer, and the wires that I connected together were black + black/white. This makes the ignition switch circuit complete so that you can start it, but the computer ends up throwing a check engine code because your driving around in neutral.
post #9 of 9 Old 09-16-2006, 05:54 PM Thread Starter
catalyst319
The extra wire on the 97 and newer switch is for the overdrive gear. What I ended up doing to get rid of the check engine light is run the overdrive wire to the blue hot/ignition wire. The car will still start with the neutral position wire gounded, and having the power wire hooked up to the OD wire. I had to use some creative cutoff wheel manuevers to get the remnants of the original NSS off, but I think the older (six wire) NSS can be used by hooking up the OD wire where the wire for gear 3 would go.
Need a Neutral Safety Switch BatmanGTO XJ Cherokee Technical Forum 2 09-26-2008 03:38 PM
neutral safety switch wildchild XJ Cherokee Technical Forum 7 09-18-2008 08:55 PM
neutral safety switch SteveJcoYJ XJ Cherokee Technical Forum 13 03-29-2008 03:17 PM
Neutral Safety Switch GiddyupJeep XJ Cherokee Technical Forum 9 08-04-2006 12:06 PM
Neutral safety switch fourlow XJ Cherokee Technical Forum 1 02-06-2004 09:19 PM
