neutral safety switch - JeepForum.com
post #1 of 14 Old 02-26-2008, 12:05 PM Thread Starter
SteveJcoYJ
The neutral safety position switch, or something like that, is shot on my trans. The check engine light came on an I ran it through Modis, did a couple tests an it came up as that being the problem. I removed the switch but broke the stud part of the switch removing it, i called everywhere an the best price whole sale is 280$, i don't have that laying around so i took it apart cleaned it out an put it back on, the stud is cracked but i still tried putting it on, hopefully that'll hold for a little. What I'm wondering is if anyone knows a place i could get one for cheaper then that in case this peace does go ? ( I already called around to junk yards ) thanks
SteveJcoYJ is offline
post #2 of 14 Old 02-26-2008, 12:22 PM
cid98
Check ebay. I got my NIB OEM NSS for $109
cid98 is offline
post #3 of 14 Old 02-26-2008, 12:32 PM
jrn1023
jrn1023 is offline
post #4 of 14 Old 02-26-2008, 04:47 PM Thread Starter
SteveJcoYJ
thanks alot, its funny i always check their for everything else first usually, i just didnt figure anything like this would be
post #5 of 14 Old 02-26-2008, 04:49 PM
jshaab2
question but what does this nss do?
01 xj sport . SS headlights sound system . dakota AT's 235/75 sound system and front and rear recovery, CB . AUX lighting EXIT 105 NJ
jshaab2 is offline
post #6 of 14 Old 02-26-2008, 04:57 PM
RBxj
It allows you to start the engine only in nuetral or park, and it also activates your back up lights when in reverse.
RB
RBxj is offline
post #7 of 14 Old 02-26-2008, 08:34 PM
redsoxski
redsoxski's Avatar
take a look at OEMdodgeparts.com
redsoxski is offline
post #8 of 14 Old 02-26-2008, 10:28 PM
kellen
If the early 90's fit your year then I got one for 40 shipped.
kellen is offline
post #9 of 14 Old 02-26-2008, 11:16 PM
gilby7887
1991 XJ Cherokee
I say you go to a junk yard and pull one and just to be safe open it up and re grease everything. make sure the springs aren't stuck,
I used this link to help me out
http://autorepair.about.com/library/a/1i/bl713i.htm
gilby7887 is offline
post #10 of 14 Old 02-27-2008, 11:51 AM
nascartony05
1994 XJ Cherokee
nascartony05 is offline
post #11 of 14 Old 02-27-2008, 03:42 PM Thread Starter
SteveJcoYJ
well the check engine light still hasn't come back on so hopefully its gonna work for a bit
but thanks a lot guys
post #12 of 14 Old 03-29-2008, 01:12 PM
underceej
NSS - override?
Newbie on this forum - and found this NSS thread.
...please redirect and/or advise if I need to repost (not intending to 'hijack' this thread)
I have a question with re: to the possibility to override the NSS (start in any position)
I am converting one of my Jeeps to a rock-crawler and was wondering if the NSS could be grounded or an override so I can start in any gear.
Thanks,
.cj
1991 - YJ
1994 - XJ
underceej is offline
post #13 of 14 Old 03-29-2008, 04:10 PM Thread Starter
SteveJcoYJ
proabaly find more luck posting a new thread underceej
post #14 of 14 Old 03-29-2008, 04:17 PM
underceej
Thanks...will do.
Need a Neutral Safety Switch BatmanGTO XJ Cherokee Technical Forum 2 09-26-2008 04:38 PM
neutral safety switch wildchild XJ Cherokee Technical Forum 7 09-18-2008 09:55 PM
Neutral Safety Switch 97 XJ catalyst319 XJ Cherokee Technical Forum 8 09-16-2006 06:54 PM
Neutral Safety Switch GiddyupJeep XJ Cherokee Technical Forum 9 08-04-2006 01:06 PM
Neutral safety switch fourlow XJ Cherokee Technical Forum 1 02-06-2004 10:19 PM
