neutral safety switch 1998 cherokee - JeepForum.com
post #1 of 2 Old 12-01-2008, 08:54 AM Thread Starter
mike243
ok so my neutral safety switch in my jeep is shot. i cant start the thing at all. i use to be able to start it by rocking the shifter back and forth with the key turned all the way and it would fire right up. but now i cant even do that?
so can i clean it ? or is there a way to hot wire it so it can start in anygear? or a way to fix it..
also would a 1995 cherokee switch work?
thanks mike
mike243 is offline
post #2 of 2 Old 12-01-2008, 08:55 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Use the SEARCH function; there's a bunch of threads on rebuilding it / replacing it.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
95 cherokee se neutral safety switch tenball XJ Cherokee Technical Forum 5 10-03-2009 11:14 AM
Neutral Safety Switch for my 89 Cherokee 4.0L Jeepnmon XJ Cherokee Technical Forum 6 03-05-2009 08:26 PM
neutral safety switch wildchild XJ Cherokee Technical Forum 7 09-18-2008 08:55 PM
Neutral safety switch Dalamatition XJ Cherokee Technical Forum 4 04-25-2008 10:12 AM
neutral safety switch rapha XJ Cherokee Technical Forum 12 06-03-2006 10:43 PM
