#1 | |
negatives of a bored TB?
I decided that I'm going to bore my own TB to 63mm. I've read about all of the positives, but are there any negatives of the finished product? The last thing I want to do is compromise a perfectly working engine.
Jeff
#2 |
at 63mm you're gonna need a new butterfly.
#3 |
Negative is if you screw it up, you're ****ed. If you insist on doing it yourself, have another TB on standby.
#4 |
x2 that^^^^^
[B][COLOR="Navy"][ ] lllllllllll [ ][/COLOR][/B] The Trail Never Ends..... |
#5 |
Go Jeepin
63MM is rather extreme unless you have made other substantial modifications to the engine. For 63MM you should have had work done to the head, a high flow cat converter installed, free flow exhaust, and have installed some higher flow injectors and even perhaps a performance chip. Plus as stated you will need to fabricate a new butterfly.
A cat-back exhaust and a K&N style filter really compliment a 60MM throttle body and would be all the modifications needed to take full advantage of the bored TB. Your stock butterfly can still be re-used.
. FOR SALE: Wide Track CJ-7 Dana 44 rear axle. PM me for details A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases. |
#6 |
A whistle if you dont ease the edges of the sensor ports. Other than that I would agree with Tim in that its just part of the equation.
98 XJ Limited Stock XJ tire carrier for sale http://www.jeepforum.com/forum/showthread.php?t=424930 |
#7 |
Ok thanks guys, I'll go with a smaller diameter.
Jeff |
#8 |
whats a decent Bore size to get better throttle response?
Jeep XJ 97' 4.0 I6 60 mm TB Bore, ______________________________________ My Jeep isn't getting LIFTED....its EVOLVING. |
#9 |
60mm to 62mm is the usual size for the finished result. I cant really think of any negatives, except the whistle when your acceleratiing.
96 Country...Weekend warrior |
#10 |
60mm is the max for the stock butterfly, and the max I would go without a lathe.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
