negative camber - JeepForum.com
post #1 of 5 Old 06-22-2004, 05:12 PM Thread Starter
JVracer04
JVracer04's Avatar
negative camber
took it for an alignment today since i just put my lift on
they said everything was fine except my camber ... -1.00*
they said they couldnt fix it but i could buy some offset ball joints to possibly correct this problem
anyone know and any places that sell offset ball joints or has anyone else had/have this problem?
LIFETIME alignment owns
1997 Jeep Cherokee... 8" Long arm Lift - still waiting to put it on
JVracer04 is offline
post #2 of 5 Old 06-22-2004, 07:07 PM
SimpleXJ
SimpleXJ's Avatar
NAPA sells them. But at around $90 a pop they are not cheap.
SimpleXJ
'88 MJ - 197K, front bumper, 4" lift front, ford 8.8 & SOA rear
'96 XJ - 240K, 5.5" lift, 33's, F&R bumpers, removable rear spare carrier, LED tail-lights, etc.
'89 XJ - 200K on body, 20k on new jasper, 3" lift, 31's, F&R bumpers, led taillights
SimpleXJ is offline
post #3 of 5 Old 06-22-2004, 07:16 PM
wipedawg
wipedawg's Avatar
Talking
I aligned mine the other day. Mine aligned out perfectly, and I have 6 in of lift. Of course I do have a long arm kit and that might have helped . Instead of the ball joints, you might wanna get adjustable uppers and lowers to help dial it in.
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline
post #4 of 5 Old 06-22-2004, 07:27 PM Thread Starter
JVracer04
JVracer04's Avatar
enh screw the ball joints
ill just buy a whole front axle...4x4 swap here i come!
now to find a parts jeep for cheap
post #5 of 5 Old 06-23-2004, 10:37 PM
SimpleXJ
SimpleXJ's Avatar
I assume by "uppers and lowers" you mean control arms.... how exactly will those help his camber?
JV: another used axle may have the same problem. It would be cheaper to fix the one you've got unless there are other problems with it besides balljoints.
Regards,
SimpleXJ
SimpleXJ is offline
Does anyone know which wire is negative for the speakers? Jeepokee XJ Cherokee Technical Forum 1 04-07-2007 08:12 PM
Horns, lol, negative problem devile XJ Cherokee Technical Forum 2 03-28-2005 12:24 AM
Negative battery Terminal Rabindranath68 XJ Cherokee Technical Forum 5 03-13-2005 10:54 PM
coil negative ribwork XJ Cherokee Technical Forum 2 02-21-2005 12:56 PM
negative camber BillR XJ Cherokee Technical Forum 3 05-19-2003 03:56 PM
