Quantcast Negative battery Terminal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Negative battery Terminal
Old 03-13-2005, 09:22 PM   #1
Rabindranath68
OK i just recently got my 98 CHerokee sport and i trying to start it the other day and it wouldnt turn over and no lights were on...
Popped the hood messed with the terminals and the lights came back and started beeping at me like wehn you leave the lights or keys in ignition ect...
But anyways on my 95 the negative terminal is grounded to the frame so my question is are the 97+ cherokees not grounded to the frame from the negative terminal?
Thanks in advance
98 Cherokee Sport
163,000 miles
Roof Rack w/ 2 walmart lights
30x9.5 Bridgestone Revos
Stock
Rabindranath68 is offline   Reply With Quote
Old 03-13-2005, 09:26 PM   #2
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
I can't remember exactly where the cables are, but their is a braided strap going to the block and firewall if I remember correctly. Are your terminals clean or filled with all that nasty crud?
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Old 03-13-2005, 09:28 PM   #3
982doorxj
From what I can rememeber....
The negative should still be grounded to the frame/body, but the cable isn't too substantial....I added a second cable to mine just to make sure....But i have a replacement battery with top and side terminals, which allowed me to use the extra terminal...
Sounds like a good cleaning would solve the problems though...
[COLOR="Red"]
===============*SOLD*===================[/COLOR]
98 2-door Base model XJ 4.0 | AW4 | NP231| 31x10.5 Cooper Discoverer STT's on 15x8 Cragar Black Soft 8's
Daystar Spacer and Shackle Lift | Quadratec HD Leafs |Surco Roof Rack w/ spare mount
[COLOR="Red"]
982doorxj is offline   Reply With Quote
Old 03-13-2005, 09:32 PM   #4
twisted_ed
i did the same when i added my 3000+ watts of audio equipment i made a big huge negative jumper to the frame right beside the battery, you will probalby find that the negative cable on the battery goes to the starter then from the starter or engine block you will see that small "dont take much power till it melts" ground to the firewall. add yourself another heavy ground wire from the battery to to a good ground as close and as short as you can fro mteh battery. cause when you add alot of accesories ie. lights and amps you will need it or u risk that little flat braided ground to melt, and beleive me it will.
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
My Jeep
twisted_ed is offline   Reply With Quote
Old 03-13-2005, 09:36 PM   #5
JeepCrazyKid
All cherokees ground to the body. The negative cable coming off the battery is a split cable that grounds to the body on the fender wall and down by the ignition coil.
Sounds like your negative (or positive) cable on the battery isn't tight. Take off the cable clamps, and use a metal file to file down the ends of the clamp so when you tighten the bolt, the two ends won't touch. Don't get carried away with the filing, because that metal is very soft.
JeepCrazyKid is offline   Reply With Quote
Old 03-13-2005, 10:54 PM   #6
Rabindranath68
The terminals are clean i think that the old terminal is just getting worn down cause its as tight as it can possible be on the cable...
Yeah my 95 has a nice thick cable spliced off from the negative to the side of the fender, my 98 doesnt and if it is just one small cable thats grounded by the started then y eah i am just going to get a larger ground and ground it to the fender...
I will prolly change the terminals to something that doesnt look so cheap lol...
Thanks
98 Cherokee Sport
163,000 miles
Stock
Glock Forum
