Need Your Opinion! - JeepForum.com
post #1 of 5 Old 05-11-2010, 08:50 PM Thread Starter
bliberty_21
Need Your Opinion!
I am sure i am going with a rough country 4.5" lift for my xj. With that said i was curious which 4.5" kit to go with. They have the basic 4.5" complete kit and then they have the x-series 4.5" complete kit. As far as i can see the x series kit looks like the way to go but i was curious what the atvantage to having a drop pitman arm and the x flex upper and lower control arms Those two things and the quick disconects seem to the only difference in between them. So, if you could give me your opinion i would be grateful.
Thanks
bliberty_21 is offline
post #2 of 5 Old 05-11-2010, 09:13 PM
99Greenmachine
Just run the 4.5 LA kit from RC...end of story
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #3 of 5 Old 05-11-2010, 09:16 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The X series also comes with full replacement leafs and an adjustable trac-bar. Don't use the drop pitman arm though as it will change the angle of the drag-link without changing the angle of the trac-bar and causing bumpsteer.
xjfever is offline
post #4 of 5 Old 05-12-2010, 12:46 PM Thread Starter
bliberty_21
With either kit I was going with full leafs so that's not a problem and the adjustable trac bar is needed anyway. But is it worth the extra money for the x series kit? Do the x flex control arms make a lot of difference?
post #5 of 5 Old 05-12-2010, 06:17 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
If you are going to use it offroad they are worth it, but if it will spend 95% of the time on the road I would say no.
xjfever is offline
4.5 , cherokee , rough country
need you opinion hockeyfriek77 XJ/MJ Cherokee Non-Technical Forum 3 08-05-2009 07:35 PM
Used XJ Opinion bniedert XJ Cherokee Technical Forum 7 02-27-2007 12:13 PM
Need a second opinion on this one 87stangman XJ Cherokee Technical Forum 7 02-16-2007 10:07 PM
Need your opinion MDP_JeepN XJ Cherokee Technical Forum 11 02-10-2005 09:14 PM
Opinion on what to get xjrrrdx XJ Cherokee Technical Forum 24 11-08-2004 08:43 PM
