Need vac diagram - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Need vac diagram
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-07-2011, 12:46 PM   #1
LobstahJeep
Need vac diagram
I just picked up my Jeep after what was supposed to be a week long motor swap job started on 11/12/10.
Without going into detail, the motor was in fact NOT swapped out like I asked to be done (this is a whole other story).
It ran great before this fiasco, but had some hesitation and oil leaks. The Jeep runs, but there are some issues now.
1: overheats
2: PCV line on valve cover is broken
3: there are 2 open vac ports on the intake manifold that are open/lines missing
4: oil pressure gauge is pinned all the way to the right (it worked fine before Jeep was dropped off)
5: check engine light is on
6: trans kickdown cable end has snapped off
I am pretty sure I can take care of number 1, and I am almost positive that #2 & 3 have something to do with #5.
Where do I start? Does anyone have pics of those vac lines for me?
Back in it's happier days
LobstahJeep is offline   Reply With Quote
Unread 01-07-2011, 01:49 PM   #2
LobstahJeep
Well after doing some research, I figured out the vac lines. Next is why the oil pressure gauge is pinned to the right, and why it's overheating.
Any help is appreciated.
Unread 01-07-2011, 01:56 PM   #3
Holder350
1995 XJ Cherokee
Oil pressure sending unit is most likely cause of the pegged gauge.
Overheating can be a host of things....thermostat, and cap would be my FIRST suspects.
95' XJ Country - Stock Skids - Limited Slip Rear Diff
Off Road Package - 4.0 HO - AX15 - NP231
Repeal Ohms Law!!!
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline   Reply With Quote
Unread 01-07-2011, 02:21 PM   #4
LobstahJeep
I am sure if I search enough, I can find where the oil pressure sender is, but can someone just tell me in here?
Unread 01-07-2011, 07:46 PM   #5
Holder350
1995 XJ Cherokee
Next to the oil filter and distributor.
Repeal Ohms Law!!!
