Need some opinions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Need some opinions
ROGUE FAB Drill Press Reduction Kits – 1:2 and 1:4 ratios Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 03-02-2004, 12:36 PM   #1
b(k)ill94xj
Need some opinions
ok so im driving home today in 5th gear on the highway, all of a sudden i hear a knocking sound, so i slowd down and it was getting quiter, shift into 4th gear its gone. ok that was wierd shift back to 5th real loud knock knock knock. Mind you i was doign a constant speed when it started. so i came to a stop sign it was gone, speed up it does it again, whenever i shift to 5th the knock comes....now the knock comes all the time. THe only time i dont get the knock is if im drivign in 4 wheel drive.
with the jeep not moving when i rev the engine (tranny in Neutral) i hear the knock. i cant figure out where in the driveline it is coming from. any ideas??
o yea, its not the engine i check that its somewhere in the driveline and all the sh!t that moves with it....
Rocks bite hard, but trees just piss me off...
97 Wrangler sport - 2 inch RE BB - Teraflex adjustable trac bar - 3.73's d30 and d35 - 31x10.5 yokhama geolander's - 15X8 American Racing Outlaw 2 wheels 3.75 backspacing - JKS LCA skids - hella vision headlights - Alpine amp and 6.5 type S speakers
94 Cherokee Sport - 3.5 Rubicon Express Kit - RE adjustable trac bar- 31X10.5 Kumho Venture MT's - 15X8 Crager Soft 8 Class III Hidden Hitch - Hand Throttle - High flow cat w/ Delta Flow 40 muffler Transfer Case Skid Plate Removable Doors --SOLD :( :( i miss it so much
b(k)ill94xj is offline   Reply With Quote
Unread 03-02-2004, 01:02 PM   #2
n1ywb
Thats a weird one. I'm gonna put my money on the driveshaft. You have a pretty tall lift, do you have a SYE? If not the slip yoke might be flopping around because it's barely engaged. Have you checked the u-joints?
n1ywb is offline   Reply With Quote
Unread 03-02-2004, 01:47 PM   #3
b(k)ill94xj
good call!!! when my dad got home i asked him and he said to check them and there is alot of playi nthe back ujoint, so im hoping that is the problem! thanx for the sugguestion.
Unread 03-02-2004, 02:04 PM   #4
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
Yo Bill I gotta change mine too, so let me know when your doing yours so we can buy it and do it together.
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
